cant get accurate reading on dipstick
Old Aug 24, 2005
Jas88's Avatar
Jas88 is an unknown quantity at this point
I cant seem to get an accurate reading on the dipstick, I have a 2003 civic EX and I first thought it was because the engine was still warm so I let cool down overnight and I still get the same problem, the dipstick shows oil all over the stick.
Anyway any help or anybody else have this problem?
Old Aug 24, 2005
tacheon's Avatar
tacheon is on a distinguished road
You sure it hasn't been overfilled? You can read the dipstick within a couple minutes of shutting the engine down.
Old Aug 24, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
Did you wipe it off completely then put it back in, and then check your oil level?
Old Aug 24, 2005
Jas88's Avatar
I did wipe it off before putting it back in, and I dont think its overfilled because even after I come back from getting the oil changed i have the same problem.
Old Aug 24, 2005
tacheon's Avatar
Well, the fact that you look at it after the oil has been changed doesn't confirm whether the oil was overfilled or not. Perhaps you can describe or better yet, take a picture as to what you mean by oil is all over the dip stick. Even if you didn't wipe the dip stick prior to checking, the oil will settle to the lowest part of the dipstick a couple minutes after the engine has been turned off. I have a feeling you're looking at just trace amounts of oil on the upper portions of the dipstick. The level of the oil is indicated by where the entire width of the dipstick is coated in oil.
Old Aug 26, 2005
djmota's Avatar
sounds like its over filled to me. Somebody probably put in all 4 quarts instead of 3.75
Old Oct 12, 2007
rcelefano's Avatar
rcelefano is an unknown quantity at this point
Re: cant get accurate reading on dipstick
I have the exact same problem actually. The oil is just spread everywhere along the stick, streaks everywhere. I put in 3 litres (1 litre bottles) and then started to measure using the dipstick. But every time I pulled up the dipstick, oil was just everywhere on it. Yes I did wipe it every time I put it back in.
SimpleUser
Apr 24, 2021 02:54 AM
mjdiaz89
Jun 21, 2016 09:26 PM
JetsterDajet
Aug 15, 2015 08:07 AM
Dangerousjordan
Jul 27, 2015 03:43 PM
robbie374
Jul 7, 2015 02:56 AM
