Power Window Switch broken
On the driver's side control panel, the passenger front window switch will only work to raise the window, it non longer lowers the window. It sounds like just a mechanical error [the switch sounds different than the others when pressed].
The window still raises and lowers perfectly when using the switch in the passenger front door.
Has this happened to anyone else? I'm going to open it up and take a look at it when I get a chance next week.
I found this link that seems to be related [i hope my switch isn't all burnt out like that..]: http://www.7thgencivic.com/forums/sh...d.php?t=212959
Thanks!
Ed
Thanks!
Ed
if the window rolls up and down with the passenger switch, then you can already eliminate the window as the problem. if it doesnt roll down with the master switch, the master switch is faulty. replace the master switch.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
beveragemp
May 25, 2015 07:11 PM
