Fender Problems
Old Aug 25, 2005
01civicexboy's Avatar
01civicexboy is an unknown quantity at this point
Fender Problems
Hey all..
I recently pulled my right fender off to pop some dents out. The dents were taken out and I fitted the fender back on. The allignment now seems to be around 2 mm's off of what it should be. The door still opens and closes without rubbing. I used the left side to compare and the top of the fender is closer to the door than the bottom part of that same fender. Could the metal fender mounts be bent? If so, is it as easy as unbending them? Thanks for any replies!
Old Aug 26, 2005
kool-aid's Avatar
kool-aid is an unknown quantity at this point
The fender has adjustment, don't sweat it. Loosen up all the bolts and start at the bottom of the fender,the one by the rocker panel. Set that lower gap first , then tighten, then work your way up the door, tighten the one on the hinge pillar then work your way to the ones inside the hood. Start at the one nearest your windshield and work your way forward toward your lights. Set your gap with a stir stick with some masking tape around it so you don't scratch your paint , when you have it set where your want, tighten the bolt.
Old Aug 26, 2005
Thanks man I appreciate it. So what you saying is I dont have to take off the fender? All I have to do is loosen all of the bolts on the fender..... There are screws near the headlight, do I need to loosen them too?
Thanks again!
usajags84
15
Aug 19, 2015 03:12 AM
Death.by.low.
Jun 14, 2015 06:31 PM
ej8
Apr 13, 2015 06:36 PM
mj1010
Dec 22, 2001 06:55 PM
johnnieblazze
Dec 6, 2001 03:07 PM
