New spark plugs and WORSE gas mileage...
Old Sep 12, 2005
sKwiD's Avatar
I Queef > You
sKwiD is on a distinguished road
Recently I put in some Denso Iridium IK20's in replacement of my stock spark plugs. The car does perform more smoothly, however my gas mileage has decreased about 3-4mpg instead of increasing by this number. I'm pretty sure I installed the plugs correctly.
Possible problems: I got some new tires on a day after I put the spark plugs in. 205/40/17 --> 215/40/17. I don't think the small amount of extra rubber could cause my mileage to decrease THAT much, could it? I run super huge sidewall tires on my stock steelies (195/65/15) and my gas mileage is usually about 32-34 still. Before I got my new tires and spark plugs in I got 32-34mpg also. When I calculated my fillup last night I only got 29.
Any ideas?
Old Sep 12, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
so ... are you running 17" rims or steelies?
are your driving habits exactly the same?
going from 15" to 17" will decrease milage ...
Old Sep 12, 2005
zen_master's Avatar
hm.............honestly..
that's actually the number that i got....29...
im using stock size.....
i wonder whether it is caused by the plugs or not...
have u checked ur tire pressure?
Old Sep 12, 2005
sKwiD's Avatar
I Queef > You
Driving the same, if not less aggressive.
Tire Pressure (Hot) is at 35psi.
I'm running 17's. But I'm comparing the gas mileage to when I had the 205/40/17's.
Maybe I screwed in the spark plugs too tight, or too loose...
Old Sep 12, 2005
ha finally it gets proven. Use stock double platinum! If you checked tire pressure (should be 30psi cold, never measure hot), and made sure the plugs are torqued (with a proper torque wrench) to 13ft/lbs, then its the plugs that are the problem. I've gotten my highest mpg using stock plugs.
Old Sep 12, 2005
zen_master's Avatar
heee....gearbox seems to be happy with it. LOL
well, again, my .02..
first, re-torque the plugs to 18N-m.....
then, check ur tire pressure in cold morning, adjust it to....31psi Front, 30psi back....
ACTUALLY....i did these...and seems like it's getting a better mileage now....and less engine noise at 3000~4000 rpm.....
before, it was a bit "growling" at that range..
Old Sep 12, 2005
sKwiD's Avatar
I Queef > You
I don't have a torque wrench... Thanks for your help guys.
thana
Jun 15, 2020 07:05 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
TopFuel
Jan 26, 2002 06:03 PM
MikeyBoy
Jan 26, 2002 06:45 AM
