Broken Wheel Bolt and Manifold stud
Old Aug 19, 2005
jbrown59's Avatar
CIVIC USER
jbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trustedjbrown59 should not be trusted
Angry Broken Wheel Bolt and Manifold stud
I am trying to replace a wheel bolt and a manifold stud and this is the last chance to get some advice before I take it to the dealership. The manifold stud is the screw that is actually connected to the block. Any advice would be appreciated. I also live in Southern Cali and will pay a mechanic to repair these. But Id rather do it myself so leave some feedback. Thanks
Old Aug 19, 2005
streetglower's Avatar
Is the wheel stud that broke in the front or rear? If it is the rear it can easily be knocked out and a new one put it. Just need a few washers and a lug nut to do so. If it is in the front, have a shop di it because the hub needs to come off the knuckle assembly.
Now the exhaust manifold studs can be replaced. Just by a new one and remove the old one and tap the new one in. I am not sure the proper way on doing that, but someone might respond who knows how.
Old Aug 19, 2005
jbrown59's Avatar
CIVIC USER
Ok so Ill go to a shop for the wheel bolt because it is the front. However, I need more info on the manifold bolt because I will do it myself. The bolt is sticking out about 1/2 of an inch, just enough to be seen the the hole where my header is. Sticking out just a bit through that hole. Anybody else have any feedback on my issues.
Old Aug 19, 2005
pon55's Avatar
To remove the stud you will have to take off the header,put some "Liquid wrench" (penetrating oil) on the stud near the block! put it on like 4 times with 30 minutes in between. Get a really good pair of visegrip pliers and a hammer.
Now the good part, put the visegrips on the stud really tight. As you try to turn the stud (not too much pressure!!!!) tap the end of the stud with the hammer! Turn both tighten and loosen, as soon as it starts to move go both back and out slowly!
It will work, but take your time!!!!!!
Old Aug 19, 2005
Jrfish007's Avatar
^^^ yeah, take your time adn walk away if you get fustrated... don't brake it
Old Aug 19, 2005
jbrown59's Avatar
CIVIC USER
thanks for the info, check back on sunday. I have to work today and tomorrow so it will be bright and early sunday morning. Anyways just ordered new headstud, gasket and a few other screws from honda dealership and I wanted an estimate on this procedure......138 dollars if they can remove it with stud removers, or 300-400 dollars if they have to drill out the stud....Ill take my chances. Thanks again guys
Old Aug 19, 2005
pon55's Avatar
WOW, those prices are not bad!
Old Aug 19, 2005
jbrown59's Avatar
CIVIC USER
Southern Cali, Orange County.....what can I say, we are a bunch of spoiled brats
Old Sep 19, 2005
jbrown59's Avatar
CIVIC USER
Anybody know what size bolt for the wheel bolts????
cukaracha
30
Jul 26, 2015 12:01 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
hayden55
Jul 8, 2015 11:38 PM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
