Upper Mounting Bolt on Alternator Problem
Old Jul 3, 2015
trellex's Avatar
trellex is an unknown quantity at this point
I'm replacing my alternator. Everything was going smoothly until I reached this hitch: The upper mounting bolt was completely missing from when I removed it. So, obviously I went to the stealership and got a new one.
Here's my main problem now: there isn't enough clearance to get the bolt to insert, as seen in attached picture.
Anyone have an ideas? I thought about lifting the engine, but I've never done that and wouldn't know where to look.
Old Jul 4, 2015
Re: Upper Mounting Bolt on Alternator Problem
Unbolt the mount, raise the engine.
Old Jul 6, 2015
emich's Avatar
emich is an unknown quantity at this point
Take off the bracket, place a jack under the oil pan ,play up and down. Another useful thing you can do : Sharpen the end of the bolt a little like a pencil it helps a lot getting it to the tread in case the alternator bolt canal is not straight
Old Jul 9, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
is that even the correct bolt (length)? I didnt have that problem with my alt.
Old Jul 9, 2015
emich's Avatar
Or using long pray bar (2x4 will work too) move the engine and push the bolt.
cukaracha
Jun 4, 2015 07:47 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
thesushiboy
Apr 12, 2015 02:54 AM
veloce
Nov 10, 2001 01:19 PM
