How to empty gas tank?
Old Sep 18, 2005
AzNDrivn's Avatar
I Sell Magazines!!!
AzNDrivn is an unknown quantity at this point
Alright, someone put motor oil in my car and i've been trying to empty out the gas tank but no luck so far. Anyone know how to empty the gas tank or what to do in this situation. It smokes really bad and shakes at idle.
Old Sep 18, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Tried a siphon hose? And how do you know you have motor oil in the gas? How much?
If you thin it enough with more gas, it'll burn allright. But it'll smoke.
Lastly, you'd have to pull the fuel line and drain it that way.
Old Sep 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Drill a hole in it, but I don't think you want to do that. You could pull the line, or drop the tank and drain it. There's gotta be something in the manual about how to drain fuel.
DO NOT try to run it out, you'll have so much **** build up in your engine, injectors, etc... it won't be funny.
Old Sep 18, 2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
Gas tanks usually have a drain bolt/plug at the bottom. Try finding it first. As Boilermaker saids oil will wreck havoc to your filters, injectors, as wells as O2 sensors, and catalytic converter.
Another method you may want to try is to unhook the fuel line in the engine compartment (prior the fuel filter) and put a solvent-safe tubing on the fuel line. Turn on the ignition (don't crank the engine) and let the fuel pump do the work for you. Be EXTREMELY careful with spark when you do this. Have a fire extinguisher on hand just in case.
Old Sep 18, 2005
streetglower's Avatar
well the manaul suggests you use a hand pump, hose, and container suitable for fuel and draw the fuel from the tank. You would have to go at it from the top where the fuel pump assembly is. there is no bolt/drain plug on the bottom of the tank.
How did someone put oil in your fuel tank? Wasnt your fuel door closed?
Old Sep 18, 2005
AzNDrivn's Avatar
I Sell Magazines!!!
Well too late, as soon as I read the first response i added a couple gallons extra gas and started running. It ran fine for about 3-4 hours then just now it idles really really bad and the check engine light came on. I had my door unlocked and ran in a store for about an hour. Came back and saw my gas cap open, big 2 gallon motor oil container right below it,
and some of the oil on the side of the car.
Old Sep 18, 2005
EX4Dr's Avatar
Most likely your O2 sensors and Cat. are shot. The fuel filter is relative cheap to replace but the other two items are not. Cheap route is to find used parts from salvage yards.
Old Sep 19, 2005
tinman's Avatar
2 GALLON??!!! Damn! Had you said that to begin with, I would not have suggested to run it out. A quart would have been OK in a full tank. I'd have driven it out, though, not idled. I've had premix in my car before and drove it out without problems.
Old Sep 19, 2005
AzNDrivn's Avatar
I Sell Magazines!!!
so any suggestions? I tried using a hang pump but no luck.
Old Sep 19, 2005
the only other thing I can suggest is to try (I mean try) to drop the tank with everything in it if a pump wont work. Will be hard as hell. BTW, why doesnt a pump work?
I have a feeling though with that much oil in the car you will probably need to flush out your fuel system.
Old Sep 20, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
Oh man, I don't really know what to tell you about that one but I sympathize for you. That really sucks.. stupid @$$holes always have to mess with other peoples stuff.
Maybe I'd file that as vandalism and claim it on insurance..
Old Sep 20, 2005
tacheon's Avatar
tacheon is on a distinguished road
I'd be willing to bet you have some serious injector, catalytic coverter, as well as oxygen sensor damage at this point.
Old Sep 20, 2005
tinman's Avatar
The gastank might have an anti-siphoning screen in it. If it does, you can't pump out the tank. But I doubt it. Honda has to be able to empty the tank for service.
You could take the top off from the back seat, remove the fuel sender, and pump it out from there. Just be VERY CAREFUL. No power, no smoking.
Old Sep 20, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
You cannot siphon it from the fuel door it is blocked. You have to take out the fuel pump and take out the gas that way from inside your cabin. Sorry theres no other way.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
bsmiley
31
Sep 1, 2015 06:11 PM
cwisenbaker06
Aug 19, 2015 04:29 PM
shaejb15
Jul 27, 2015 03:48 PM
Kyles24
Jul 16, 2015 10:14 PM
