Any other 2001 with the fix-A/C,Brake Light &P/L Problem
My Air C/ doesn't function, Brake Light always on and Power Locks do not operate. I supposed that is an electromechanic problem. If any other member with this problem? I need to Fix It!
Sometimes operate properly and sometimes don't operate. Is a very rare problem to fix it.
check all the fuses, then check the grounding if you know how to use a multimeter. If you have access to a multi meter, we can help you out.
sounds like a faulty or poor ground. When I get home I can look through the manaul and see if the same ground operates those circuits. Did all of these all go out or happen at the same time or happened at different times?
well I searched through the manaul and didnt see that any of these were connected in any way. If the brake light stays on at all times, first check to see if you are low on brake fluid. As for the door locks, do they all not operate?
I'm go to my nearest Honda Repair Dealer and the system shows the Fuse Box in the interior of my car has faulty ground. Finally, I changed that and the problem was corrected. The new OEM Fuse Box cost me $254.75 and labor $130.00. Uf!
Originally Posted by triryche
I tried it to say the under dash fuse box was crossed and the dealer replace with a new one.
I wonder if the dealer didn't just replace the fusebox for $$$ and move a wire that was the real problem. A fuse box is pretty straight forward.
Originally Posted by tinman
You know.... I'm still trying to figure out how that could even HAPPEN.
I persoanally feel the dealer did screw you over, or the technician did and saw that there was a simple repair that was needed and wanted to make alot more money. I agree with tinman on that. I would call the dealer and ask them about that.
question: Is possible that the fuse box was crossed? The dealer says that is the cause of the problem
Now, if you modded your car and added anything to the electrical system that could have overheated the fusebox, causing a short, it's your fault.
Well I figured out how this possibly could have happened. After reading though the manaul, I found that the under dash fuse box is the mulitplex control unit. And all 3 of those components go though the control unit and I see how it was possibly to have the faulty fuse box. At the time I didnt know that the control unit was the fuse box.
I guess the tech may have done a series of tests at the control unit and this was found. But it could have also been a way to make money.
My cousin's car has this exact same problem. It happened after the amp and subs were removed, but the aftermarket player is still installed. Brought the car to dealer 2 or 3 times and they still couldn't figure out what the problem was and charged like $200 for fixing nothing. They said her a/c needs a new compressor and that they had to troubleshoot some more at a later date.
Now that I have an idea of what the problem is, should I bring it back to them with this new information? If so, do you think the money already spent on their "troubleshooting" should apply to the fix.
One problem is they are the only Honda dealer here.
ashleymmackey
Apr 18, 2015 09:48 PM
