How long is Battery Life?
Old Aug 29, 2005
Roosbok's Avatar
Roosbok is an unknown quantity at this point
I have had my Civic for 4 years with the original battery. The green light is still on, but we get severe winters here. Should I play it safe and get a new battery this fall, or are these batteries good for 5 years? Has anyone changed or had to change their battery yet? Thanks.
Old Aug 29, 2005
streetglower's Avatar
batteries last untill they die. Some people have had batteries last for 5 years. Others have had to replace there battery after 1 year. No one can tell you your battery will last 5 years because they dont know.
If the battery is performing up to standards, but you are concerned, have it load tested. Now the green light only tells you the condition of one cell in the battery. there are 6 cells in a battery. So that one cell could be good and the others failing or getting weak. Best bet is to load test the battery.
Also if the battery is a add water battery or partially maintanence free, get a hydrometer and test each cell of the battery. this will test the electrolite in each cell and give you the state of charge in that cell.
Now I have had to replace my battery last year, and I had it only 2 years. My mom had her battery replaced before 1 year. They all vary.
Old Aug 30, 2005
CIVIKRACIN's Avatar
CIVIKRACIN is an unknown quantity at this point
my battery onlylasted three years
Old Aug 30, 2005
Jrfish007's Avatar
Originally Posted by 1sikEM2
go to autozone or something and they do a free check. ur battery should have between like 12-15 volts is normal.
A dead battery can have a voltage of 12V, just when a load is applied it will drop, hence the reason autozone load checks them.
Anyway, yeah, just use it till it dies. You can tell when they are about to go out, when it gets cold out, it will have trouble starting, when it does this a couple of times in a row time for a new battery. I know people here in Ohio (we get some bad winters too) who have had there battery for over 10 years without a problem.
Old Aug 31, 2005
CIVIKRACIN's Avatar
hey does giving people jump starts reduce the battery life
Old Aug 31, 2005
thefivespeeder's Avatar
thefivespeeder is a jewel in the roughthefivespeeder is a jewel in the roughthefivespeeder is a jewel in the rough
it puts a hell of a load on your charging system, i would say it more likely may reduce the life of your alternator [diodes/voltage regulator] because of the voltage spike, the more dead the other guys/girls battery is, the more it is the load on your system
Old Sep 1, 2005
CIVIKRACIN's Avatar
yeah i guess ill stop helping people out when they need a boost unless they contribute to buying a new one
beantech
Jun 15, 2015 07:09 PM
Hiryuu
Jun 6, 2015 03:00 PM
Black91civic
Jun 6, 2015 08:15 AM
jackoncruzpr
May 24, 2015 12:24 AM
jackoncruzpr
Apr 16, 2015 12:29 PM
