oil leaking out of valve cover
Old Sep 5, 2005
puidokas's Avatar
puidokas is an unknown quantity at this point
I got a big problem, my engine is leaking oil out of a couple of valve cover bolts that i finally realized that were stripped out. I got some lock-tite aluminum repair kit and it helped the bolts out a little bit, but im still leaking(or burning) about 1/2 a quart a week. Should i just tap a bigger bolt in the head?
And in the case of burning oil, how can i tell if i am?
Old Sep 5, 2005
Syke Fu's Avatar
Syke Fu will become famous soon enough
Blue smoke = burning oil.
Old Sep 6, 2005
puidokas's Avatar
if im only burning a little oil will the blue smoke still be noticeable.
Old Sep 7, 2005
tacheon's Avatar
tacheon is on a distinguished road
Yes. A small amount of oil burning will show up when you step on the accelerator. BTW, I suggest you helicoil the stripped bolt hole and use the original bolts to do a proper repair rather than tap and put a larger bolt in.
Old Sep 7, 2005
Jrfish007's Avatar
SO what's stripped out agian? I seem to be a little lost on what is stripped, is it the valve cover bolts? If so you can replace the studs. I don't recomend going to long in this condistion, the wrong loads on the valve cover can kill the cam baring.
Old Sep 7, 2005
puidokas's Avatar
Helicoil???????
Old Sep 7, 2005
tfnaaf's Avatar
BLDNPSI Mod
Helicoil???????
Most auto parts stores should carry these
Old Sep 7, 2005
tacheon's Avatar
Yes. Helicoil. It is the proper way to do a threaded hole repair in metal. You aren't the first nor will you be the last person who has damaged a threaded hole. A Helicoil kit is the proper way to repair the damage so it is nearly good as new again.
Old Sep 8, 2005
puidokas's Avatar
thanks alot
mattdoc
Mar 14, 2017 12:10 PM
LionSpratt
Jan 29, 2017 11:07 PM
Supramk3
May 11, 2015 07:55 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
