transmission noise please help
Old Sep 25, 2005
2003hondacivic's Avatar
2003hondacivic should not be trusted2003hondacivic should not be trusted2003hondacivic should not be trusted
i have a 03 with a m/t
i have a really bad noise when the trans is in neutral and the clutch engaged?
the trans only has 72,000 on it
Old Sep 25, 2005
streetglower's Avatar
to me it sounds like a bad input shaft bearing. I know that with the clutch pedal fully depressed and the clutch disengaged, a bad pilot bearing can be heard. And a bad throwout bearing can be heard right after the free play point when the clutch pedal is depressed. right when the clutch fingers make contact with the throwout bearing. Someone else please confirm that for me.
Old Sep 26, 2005
zdriver's Avatar
zdriver is an unknown quantity at this point
it is the input shaft bearing, had it replaced under warranty last fall at 98,000 miles
Old Sep 26, 2005
zdriver's Avatar
might as well change your clutch disc while your clutch is out free labor
Old Sep 28, 2005
ok cool
do you know what it will take to fix it myself i know i have to pull the trans
Old Sep 29, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
^^^^ yeah diy please someone
Old Sep 30, 2005
zdriver's Avatar
http://honda-tech.com/zerothread?id=596873
thats how i found out my bearing was bad
Hqly2001
22
Jul 12, 2015 06:44 PM
Jul 12, 2015 11:54 AM
1khilari
Jul 9, 2015 08:12 PM
fatih717171
Jul 8, 2015 12:14 AM
fvckbg
Jul 7, 2015 07:08 PM
