Check Engine Light on, bring to dealer under warranty?
Old Aug 14, 2005
nyyanks81's Avatar
nyyanks81 will become famous soon enoughnyyanks81 will become famous soon enough
The darn CEL turned on today and my car only has 1300 miles. Am I allowed to bring this to the dealer for them to check it out under warranty?
They are not gonna make me pay for finding out why the light is on and fix the problem right?
I'm planning on going to the dealer first thing in the morning since I tried Autozone tonight and they told me it was too late for today for them to check codes.
How long does this take at the dealer? Is this like an all day event?
Old Aug 14, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
dealer will fix it free cuz warranty no way a car should have the cel on when almost new.
Old Aug 14, 2005
streetglower's Avatar
doesnt matter how old a car is or how many miles a vehicle has, a problem can occur at any time. I have seen cars brand new on the lot with less then 5 miles on it with the SRS light on, check engine light on, ABS light on, everything. Some parts last longer then others.
Now depending on what the actual code is and the actual problem is, depends on how long it is there. To be honest, they will probably keep it a few days, based on experience. They work on what is already there, so you basically have to wait in line.
Old Aug 14, 2005
nyyanks81's Avatar
The engine light turned on after a few minutes of driving on the expressway heading to the mall. On my way back home from the trip, I was merging onto the expressway and stepped on the gas to avoid getting rear ended by oncoming traffic and got it up to like 4-5K. It was raining a bit, and I felt the car like shake for like 2 secs (it was just 3 or 4 shakes) immediately after I stepped on the gas and merged onto traffic. After that, the car didn't shake anymore the rest of the way. Was that the rev limiter? or could it be the the result of the CEL?
Also I did feel that throughout the way, it felt a bit slugglish in accelerating from a stop. I mean it took just a little more effort for the car to accelerate.
Old Aug 14, 2005
honestly it could be a number of things. I really dont know. Unless you knew what the trouble code is, that would help more toward what is the problem. But if it is under warranty, dont even worry about it, let the dealership worry about it.
Old Aug 15, 2005
nyyanks81's Avatar
I just got back from the dealer this morning and they told me they will try to get it checked out before the end of the day if not, tomorrow morning. They have like 45 cars ahead of me.
There were about 30 cars all waiting for service when I got there this morning @ 6:30 am lined up on the street.
Here's what the service advisor wrote on the labor instructions:
check engine light on while driving, engine feels sluggish, check & report.
I notice that on the work order, there is a labor rate printed on there of 105.00. They are not going to charge me that under warranty right?
Old Aug 15, 2005
Jrfish007's Avatar
No, if they even try to charge you for anything, just say you want to talk to their manager about the charges, and then say you would also like to talk to who ever is in charge of costumer relations. the labor charge is common because they have to report a cost they spent n the car to Honda and so forth (just book keeping) you should not pay anything while under warrenty, unless you have modified somehting and the problem is a direct result of you modification.
Old Aug 15, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Common sense next time before you bring your car to dealership next time.
-Check if your gas cap was tighten after fill-up.
-Get the code read at Autozone for free.
Old Aug 15, 2005
nyyanks81's Avatar
I just picked up the car from the dealer. The report says Code P2647 VTEC OIP L PRESSURE SWITCH HIGH VOLTAGE.
It also says perform diagnost IC test-passed. Reset system and road test operation normal no check engine light on.
The cashier said no charge and sent me on my way.
Old Aug 15, 2005
I just picked up the car from the dealer. The report says Code P2647 VTEC OIP L PRESSURE SWITCH HIGH VOLTAGE. They tested and reset.
well according to the manaul, if they tested it and everything was fine, they probably reset the ECU and checked to see if the code came back. And if it didnt, then there was a intermitent failure. Or your engine oil level was low.
Old Aug 15, 2005
nyyanks81's Avatar
I forgot to mention that when I got the car back I got the following items for free: small puddle of oil on the roof and a streak of oil on the rear of the car by the passenger door and a splatter of this dried brown stuff near the windshield fluid nozzle.
Old Aug 16, 2005
jttegx's Avatar
OMNES AD UNUM
take it in for warranty work. hope u dont have aftermarket mods...
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
