Pedal Vibrations
Old Aug 31, 2005
DDragon7's Avatar
Pedal Vibrations
Hey guys, Im pretty new to the gen 7th Civics. Now I have been noticing that my pedals vibrate a lil. I can feel the road vibration and today it was raining, when I use the wipers, I can feel the wiper motors' vibration in the pedals. Is that normal? Also the speed for the wiper at intermediate and the second setting is kinda slow compare to other cars I've driven, is that also normal?
Thx in advance.
Old Aug 31, 2005
streetglower's Avatar
Does the pedal vibrate when braking? Or just while driving?
Now if your wipers are vibrating across the windshield, either your wipers have deteriated, and you need new ones, or you are in gearboxes shoes and have a problem with your cars wiper system. (just a joke because gearbox has tried every set of wipers known to man and still has them vibrate accross the windshield).
Also the speed setting I think is pretty low compared to other cars I have driven. I think it is normal on the civics. The high speed seems like low speed on my moms car.
Old Aug 31, 2005
DDragon7's Avatar
The pedals vibrate will driving. Not sure about the during braking but I can notice it in the gas n clutch pedal.
Old Aug 31, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
hey if gearbox is reading this TRY VALEO they're around 15/wiper but they phooking rock
they don't have a 'skeleton frame' just the wiper and a spine persay and the clip...I've put them on several cars and even dry w/o lubrication of any kind they just glide hell even quiet no 'whine & grind'
Old Sep 2, 2005
DDragon7's Avatar
Bump
Old Sep 5, 2005
DDragon7's Avatar
Hmm, any1 got an answer to the vibrating pedals? N the wiper vibration is in the pedal not on the windsheild.
Old Sep 5, 2005
shroomster's Avatar
sometimes you can feel the pistons of the brakes in your pedals when you stop or the abs but the abs is a rapid pulsating action...you might be feeling a wheelbearing thats seeped out its grease and is running dry now... thats my thought
Old Sep 5, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
does only the ex have abs or is it in all of the trims? i feel mine vibrate when i'm going down hills. i have an lx by the way
Old Sep 5, 2005
only the ex has it. I actually picked up some new trico innovision wipers (the kind with just a steel beam. They wipe alot faster cause they don't drag on the windshield. You can kinda see them trying to skid, but there is even pressure so they never do. Very fast and smooth wipe. And finally too after trying 5 sets of wiper blades. I'm sticking with these. Only used in light rain so far and even with dry windshield they don't streak.
Old Sep 6, 2005
so any ideas why mine pulsates?
Old Sep 6, 2005
something with the brakes, prolly just warped rotors if it does it when going fast. Are all your lug nuts tightened the same torque? I had some vibration and swapped with new pads, but it eventually came back. Now I have some powerslot rotors and hawk pads waiting to go on soon.
Old Sep 6, 2005
A03's Avatar
A03
A03 is an unknown quantity at this point
If you feel it in the clutch and gas pedal, it might have nothing to do with brakes. The first guess I'd make is that a wheel is out of balance.. Maybe one of the small balancing weights came off and that is whats causing it. Best bet is to have the dealer check it out IMO.
Old Sep 6, 2005
DDragon7's Avatar
I'll see if its an aligment issue next year when I get sum rims cuz I hate the dealer where I got my car with passion. N the stock wheels dont have weights on them.
Old Sep 6, 2005
shroomster's Avatar
Shoot....if its your alignment you're gonna find out a lot soner than next year hehe
and if you have no weights on those rims...you got some really well balanced tires and rims probably a zero dead weight ratio
Old Sep 6, 2005
DDragon7's Avatar
My brother notice it pull a tiny bit to the left, but I havent actually tested it yet. N I dont recall seeing ne weights on the wheels.
Old Sep 6, 2005
shroomster's Avatar
even a lil pull will cause uneven tire and parts wear over time.... get the car the way you want it and then get your alignment
and again as for the wheels if you have anyone that KNOWS (ASE) or specialist run your tires on a true balance machine they can determine if you need weights or not....it is rare that setups will come out balanced evenly...just yesterday i had a tire and rim zero out I checked the calibration 3 times and spun it again and it zeroed out still...its rare but it does happen I doubt it that all 4 came out zero....but stranger has happened
Old Sep 6, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
well, there's your problem.
i guarantee, unless a crack-head qc'd your car as it left the factory, that your wheels came balanced with weights on the wheels.
however, after 70km, it's not uncommon for a weight or two to come up missing.
so take the thing to a reputable tire shop and have those bad boys balanced...
and then you can call it a day
sesi
Oct 1, 2015 02:03 PM
juicetayne
Sep 30, 2015 11:02 AM
Wariogamer
Sep 29, 2015 09:49 AM
speedlever
Sep 24, 2015 07:18 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
