How to adjust a slipped steering wheel???
Old Sep 17, 2005
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Arrow How to adjust a slipped steering wheel???
ok so everytime i get in the smallest of accidents or a hit a big bump realllll hard my steering wheel gets shifted over to the right... i mean like for me to drive straight it looks like my steering wheel should be making me turn a hard right turn lol.... anybody know what screws and stuff to undo to readjust it back to normal? is this possible? do i need to do anything with SRS too??? thanks guys for reading
Old Sep 17, 2005
um i think you just need an alignment?
Old Sep 17, 2005
REDchirp's Avatar
this is farrrr from an alignment, well to the best of my knowledge... i've just never seen a steering wheel so F'd up lol...
Old Sep 17, 2005
well thats what does it. If you align the wheels, the steering wheel should also be corrected. I had the same problem with my old jetta but didn't have the $ to fix it. Wheel would be turned to the right to go straight.
Old Sep 18, 2005
tacheon's Avatar
tacheon is on a distinguished road
You need an alignment. You can't just unbolt the steering wheel and move it. There are staggered splines on the steering wheel such that it only fits on in one orientation.
Old Sep 19, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
I think what he means is that it drives straight.. like he can let go of the wheel and the car will still go straight, but if he goes over a bump, then the wheel jerks to the right..
am I correct? Because that's what mine did.. what that turned out to be was that the passenger side strut was leaking really really really bad.. I had both front struts replaced under warranty and it was good to go after that. It's been fine since
Old Sep 19, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
He's saying that the car travels straight when you let go of the wheel, the to go straighht, the steering wheel is crooked to the right. My car goes straight as a arrow but the steering wheel is a little off, wondered about this myself?
Old Sep 22, 2005
REDchirp's Avatar
^^^ Yess you are correct... it goes straight when i'm not holding onto the wheel basically, but to go straight in the first place my steering wheel is clocked almost a 1/6th turn to the right...
Old Sep 22, 2005
streetglower's Avatar
as tacheon said, your alignment is out. Most likely your toe is out. All you need to do is take it in for an alignment and they will turn the steering wheel straight in the forward position, hold it there and adjust the toe. Then it will be back to normal.
Old Sep 22, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
If you keep getting in "Small accidents" Stop crashing the car or stop driving it..
Recentering the wheel does nothing but bias the rack off center. If your alignment is so ****ed up that your steering wheel is so off that it looks like you're making a hard turn, something is broken. Plain and simple. There's no way the rack can be that far off without damage somewhere in the steering system.
Old Sep 24, 2005
2K1Civic17"Gabe's Avatar
ummm, the steering wheel can be put on any way upside down, or whatnot. it doesnt matter. Well it does matter for alignment purposes.
They need to put your wheel straight, and align it. Your steering wheel centered, should be where you need the car aligned. (confusing?? sorry). If you put the wheel on at a different angle, it will let you turn sharper one way than the other. You dont want that though. You want a centered alignment. Whoever did yours sucked. Tell them to redo it proper.
Old Sep 25, 2005
REDchirp's Avatar
Thanks guys for the input, its going in for alignment and new Brakes/rotors tomorrow!!!!
Old Sep 25, 2005
ncirom2003's Avatar
avoid hitting things.
Jul 12, 2015 11:54 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
General 7th Gen
Jul 9, 2015 10:17 PM
CivicsClass101
Jul 9, 2015 11:14 AM
BootyDo
Jul 7, 2015 06:06 AM
