Anyone have to replace any of the dash lights yet?
Old Aug 26, 2005
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
I noticed that the orange lightbulb behind my moonroof switch is dying..it sometimes wont turn on unless i tap it. the light behind the cruise control switch is also dead...
The honda dealer wont replace the bulbs for me under waranty because they claim light bulbs are wear items.
Old Aug 26, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
ya man, you should be able to remove the cover over the switch and replace the bulb. You can use this diy below for some more ideas about led lights.
http://www.7thgencivic.com/forums/sh...d.php?t=137792
Hope that helps.
Injen
Old Aug 26, 2005
i actually replaced the cruise and moonroof light bulbs with some slightly brighter ones from an old gauge cluster. Just unwrap the old ones and wrap the wires of the new one in the same way. No soldering or anything. You just swap in its holder. I can send you a couple if you want for $1.
Old Sep 2, 2005
turboslug's Avatar
Super Hoser
i think i have a few bulbs here and there...i'm gonna go look into the bulb problem when i have some time...
the switch lights aren't that important but i'm worried about the light bulbs inside the gauge cluster..i'd hate to have to dissassemble the cluster just to change a few bulbs....and at the rate that my dash lights are dying, im worried teh gauge cluster lights will start dying too...
Old Sep 2, 2005
the gauge cluster bulbs just twist off from the back. No need to open it at all. And they use more common sizes, at least the 01 uses #74 mini.
Old Sep 2, 2005
turboslug's Avatar
Super Hoser
icic..thanks...
Old Sep 3, 2005
sharper's Avatar
sharper has a little shameless behaviour in the past
i notice the left side of my gauge cluster was getting dim. so i replaced about 3 bulbs behind the gauge cluster and it's all good now.
Old Sep 4, 2005
Roosbok's Avatar
Roosbok is an unknown quantity at this point
I don't think so, I think it is bumper to bumper warranty 3yrs. 36,000. Bulbs, brakes, and all. Some things might be just 12 months though, but I think bulbs are covered for the full warranty. I just noticed you live in Canada, isn't it something like 48,000 km. But still basically the same warranty and rights.
If you try to take of the cruise control button and break it, you might void the warranty. You might want to pursue this issue.
You can take the car to another dealer too. It doesn't have to be the one you bought the car from. You might want to get a second opinion.
Old Sep 4, 2005
no wearable items. brakes, tires, etc are not covered
Old Sep 4, 2005
Roosbok's Avatar
Aren't the tires under a separate warranty anyway from the tire manufacturer?
I guess you're probably right but it doesn't make sense to be that they can get out that easy on the brakes, wouldn't they have to be covered for at least a year?
Now that I think of it the bumper to bumper coverage might only be 12 months 12,000 mi. Wearable items like brakes and bulbs and the stereo and component type things. (maybe the battery too?) would be out of warranty. You've probably had the car longer than that, so maybe your bulbs are out of warranty.
Old Sep 13, 2005
kickoo's Avatar
kickoo is an unknown quantity at this point
dam cant i find these bulbs in radio shack? my dash is leaving me....
Old Sep 13, 2005
CraigW's Avatar
#74s ?? Find them at the auto parts store.
Old Sep 13, 2005
theprophet36's Avatar
theprophet36 is an unknown quantity at this point
the light behind my fuel guage died on me a week ago.
Old Sep 15, 2005
kickoo's Avatar
3 from the odometer....like 3 weeks ago.
the sunroof and cruise ones left me like a year ago...
im gonna try to replace all of em...**** it
Old Sep 20, 2005
darklegacy540's Avatar
darklegacy540 is on a distinguished road
So did you end up replacing all of them?
After all this, it sounds like a good reason to do the LED conversion..
Old Sep 20, 2005
i've had to solder new bulbs into the cruise/moonroof/mirror. The problem is they get way too hot in that tiny switch and overheat. My switches are all hot. I doubt this is as much a problem with the center lights.
Old Sep 21, 2005
kickoo's Avatar
LED CONVERSION? Is it a custom job that you go out and get the pieces or do they come as a kit?
Old Sep 21, 2005
its alot of work, but there are kits available. Don't know how good they are...
www.ledautomotive.com
Old Sep 21, 2005
CraigW's Avatar
WWW.LSDIODES.COM has a lot of information on LEDs
voblak2
20
May 4, 2023 02:08 PM
twtron
Apr 17, 2015 12:09 AM
dooner24
Apr 14, 2015 07:51 PM
thesushiboy
Apr 12, 2015 02:54 AM
antidote11
Dec 8, 2001 09:32 PM
