Safety/Security Items - SRS, Keys, Immobilizer, airbags, ABS Post your safety, security questions here! Airbags, Keys (immobilizer)
Airbag light on AFTER recall repair
Old May 2, 2015
voblak2's Avatar
voblak2 is an unknown quantity at this point
Hey all, I had my '05 Civic in over a week ago for the airbag recall and when I started my car this morning the airbag light came on and won't go off. I've owned the car for a month and never had a dash light come on before now. I find it a tad interesting that I just had the dealership check the airbag for the recall and now the airbag light comes on. Any ideas what this could be about or what I should do? Thanks in advance!
Old May 2, 2015
GolNat's Avatar
Prelude Owner
Re: Airbag light on AFTER recall repair
I would try reseting it first and seeing it comes back.
https://www.civicforums.com/forums/1...ght-video.html
The dealer may look at it for you since you just had it in the shop but you may get charged for it if it something that they did not cause.
Old May 2, 2015
Take it to the dealership and explain this. Ask them to double check their work.
(My shop will double check our work for free, if it is not our responsibility then we inform you there will be diagnostic fees if you want the answers.)
If the code has anything to do with the airbag(s) that got replaced....... You know.
(IF there was a problem with the recall work, 99% sure the idiot light would have stayed on immediately, before you got out of the parking lot on the day it was completed.)
If the code is for a seat belt buckle or any other part they did not touch, you own it. See what the dealer will do.
Old Aug 1, 2015
04 Honda Civic's Avatar
I had the recall performed as well. But they did not change the driver side inflator, they removed it and put the same one back anyone know why? Ezone?
Old Aug 1, 2015
GolNat's Avatar
Prelude Owner
Maybe it wasn't a lot # that was defective. Maybe your VIN was a possible car.
Old Aug 1, 2015
Only TAKATA brand inflators are under recall.
If your car was equipped with an AUTOLIV brand inflator, it does not get replaced.
The bag assembly gets pulled off the steering wheel, looked at, and reinstalled if it is not a Takata brand.
And we don't change the bag itself, only the inflator behind it.
HTH
Old Aug 1, 2015
Awesome, good to know.
The new passenger side inflators are also made by Takata..how safe should I really feel? lol
Old Aug 2, 2015
You felt perfectly safe until the fear mongers told you to be scared.
I think they have about 4 different companies supplying various replacement inflators now. You SURE your new one was a Takata?
(I have not been keeping track of what brand goes where though)
Old Aug 2, 2015
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
My CRV did the same thing. It was the seat belt switch for mine. Click on the link below.
https://www.civicforums.com/forums/4...-inflator.html
Old Aug 15, 2015
Star1967's Avatar
Star1967 will become famous soon enough
I'm having the same problem with an 2001. I wonder if it is wise to change both the passenger and driver side switches at the same time?
Old Aug 15, 2015
RIPSAW's Avatar
You sure it's both sides. My recall was just driver. The passenger bag goes up before coming fwd. I assumed the flying metal would hopefully go over the passenger's head.
They told me my fix was temporary and that I would get another recall someday. However, the fix they did satisfied the recall and none exist on my car now. So not sure if service people really know if there are another recall coming someday.
Old Aug 15, 2015
It would be wise to retrieve the code and make sure of what the issue really is before tossing money at the car.
Some of the buckles can be pricey if they have a firing charge attached to them.
It's kind of a mess right now, and there are like 17 MILLION cars from about 10 different vehicle manufacturers that are ALL going through nearly identical recalls.
I have seen new inflators from maybe 4 different suppliers (4 different brand names) because Takata could not produce new units fast enough, and I'm still not real sure if all of the Takatas will eventually be taken out of service or what will happen before this is over.
We are returning the removed inflators by the pallet load.
We at the dealers really have nothing to do with making the decisions as to what gets replaced and when. We simply check the VIN report and complete whatever recall campaign(s) it says applies to that particular car.
They have been changing and adding VINs to the recall lists in batches (I assume as warehouse inventories are built up), so we might check and order a drivers unit for a car then by the time the car arrives there's a brand new recall that applies for the passengers unit and shows up on the new VIN report.
Some of the cars originally got the drivers bag serial numbers checked and then the inflator was either replaced or reinstalled, others automatically got replaced, some have been replaced at least twice if not more, some still only get inspected to see who made it, and many cars now get the passengers inflator now too.
Old Sep 16, 2016
safetyrestore's Avatar
Seat Belt Repair & Airbag Reset - Safety Restore
safetyrestore is an unknown quantity at this point
You should need to take it your dealer and ask them why it happened. Describe all about it and ask them for double check. If they are responsible for this, then they will check where from default comes and if there is any other problem, then you will pay for that.
(We provides seat belt repair and airbag modules services with double check and give full responsibility about our work)
Old Feb 6, 2018
RickSlick's Avatar
RickSlick is an unknown quantity at this point
This happened to me exactly. They said bring it in and if it's their fault it won't be the 65 dollar fee for checking. Otherwise I'm responsible for all parts and labor. I felt cheated. I told them I never had a light until a week or so after this repair but somehow it's my fault. Then I was hung up on. My next car will not be a Honda.
Old Feb 6, 2018
All you need to do is read the fault code yourself so you know if it's related to their work or not.
If it's a code for the airbag they just replaced, take it to the dealer.
If it's anything else, you now own a new problem.
Old Feb 6, 2018
RickSlick's Avatar
The service guy said I need a special diagnostic computer to read airbag codes. I have done a little research and the light staying on means the airbag will not deploy and maybe it's electronicly not connected. I'll try o Reilly and see if the code says anything. My thing is if I see dog prints on a beach I think it's safe to say a dog walked on this beach. They were totally rude and would not give me the benefit of the doubt. Worst customer service ever. From a dealership in Roseville Michigan. Jeffery Honda. Terrible! I may write a letter or just buy a new Toyota and bring it by there.
Old Feb 6, 2018
Not always true.
Not always true.
I doubt their engine code reader will touch airbag codes, but it's worth a try.
Dog walked across the beach a week ago.
Does that mean the dog is still on the beach?
Exactly how much money have you spent with that dealership over the last 10 years?
Go ahead and get your receipts and calculator, I'll wait.
Do you understand how often dealers hear the same stories from consumers who want everything for free?
Do you work for free?
I doubt they will care.
If you didn't spend a dime in that store over the last 10 years, they aren't going to miss you one bit.
At my dealer they will recheck it and if it's their fault it gets taken care of, no problem.
If it's not their fault, you won't get any answers without paying. All you get to know for free is if it's their fault or not. If you want the answers, you have to pay the checkout fees.
Old Jun 8, 2020
RickSlick's Avatar
Originally Posted by ezone
Not always true.
Not always true.
I'll junk the car before I'd ever take it back to Jeffery Honda in Roseville Michigan where I experienced the worst customer service ever known to man. Absolutely trash.
Old May 4, 2023
David05072's Avatar
David05072 is an unknown quantity at this point
Got the air bag recall and my car was one of the victims a week later the air bag light came on 2005 honda civic
Old May 4, 2023
BrotatoChip's Avatar
Super Moderator
Take it back to the dealer. Or pull the codes yourself.
Old May 4, 2023
Colin42's Avatar
Exactly, no point in complaining here
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
bo_red
Transmission
May 3, 2015 09:14 PM
big20ugly
Nov 11, 2001 08:30 PM
