DIY: Reset SRS Airbag light (With Video)
Old Dec 28, 2010
Kennykid2002's Avatar
Kenny the Ricer
Disclaimer:
Reseting SRS light will not always fix the problem.
If problem persists, SRS light will come back on eventually.
To find the source of the problem, run diagnostic.
Most common problem with 7th gen is the seat belt sensor (which is covered under Honda lifetime warranty)
A worse problem would be airbags malfunction
Honda runs diagnostics for $68 dollars and fixes the problem for free if it is a seatbelt problem
Some will even refund diagnostic fee
[YOUTUBE]http://www.youtube.com/watch?v=boVKZqOvZGg[/YOUTUBE]
PREP WORK
Step 1:
Remove panels under steering wheel to access interior fuse box
Step 2:
Locate yellow clip inside fuse box and disconnect it
Step 3:
Attach a power wire, speaker wire, or a paper clip to both terminals of the clip
ACTUAL RESET
Step 4:
Turn ignition key on "ON" position.
Step 5:
Wait for beeping to stop.
SRS Light should turn off
Step 6:
Quickly disconnect wires
SRS Light should come back on
Step 7:
When Light comes back on, quickly reconnect wires.
Step 8:
When Light is off, disconnect wires again
When reset is complete, it will flash twice
Wait a second to see if the light turns back on, if it does, repeat steps 4~8
Step 9:
Start car to see if the SRS light has been successfully turned off.
If problems persist, run diagnostic.
Old Dec 28, 2010
MindBomber's Avatar
Live for the Twisties
Re: DIY: Reset SRS Airbag light (With Video)
Good DIY!
Old Jan 1, 2011
matt_d_83's Avatar
matt_d_83 is an unknown quantity at this point
wow...great stuff
Old Jan 2, 2011
lazlong's Avatar
"Most common problem with 7th gen is the seat belt sensor (which is covered under Honda lifetime warranty)"
**Unless you have a salvage.
Very nice DIY. Clean ride too. I had the tan interior in my first 2001 and it had uncleanable stains in the seats and floorboards in about 2 weeks. lol
Old Feb 9, 2017
MontanaProf's Avatar
MontanaProf is an unknown quantity at this point
Hi there,
Great instructions for a reset. They worked perfectly, but I've had to do this several times now.
You mention "To find the source of the problem, run diagnostic."
How do I do that?
Thanks!
voblak2
20
May 4, 2023 02:08 PM
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
big20ugly
Nov 11, 2001 08:30 PM
