Right Rear Strut Creak and another Pop?
Old Sep 22, 2005
Whelan's Avatar
Whelan is an unknown quantity at this point
My right rear strut I think has a slight issue. When going over bumps or uneven surfaces it tends to creak/squeak a bit each time. Not sure why any suggestions?
Also ocassionally when I go from a dead stop and start moving the car give a kinda pop sound, not sure why or where but it's very random and not all the time.
Old Sep 22, 2005
ragingSPAM's Avatar
I just burnt my tongue
take to dealer have them check it out if ur car is still under warranty...or if u have a friend have them check it out...
as for the strut its prolly a bad shock which is doing that...and the pop i dunno
Old Sep 22, 2005
lube rear sway bushing
Old Sep 22, 2005
01vic's Avatar
ultra super duper member
01vic will become famous soon enough01vic will become famous soon enough
my car is doing the same thing, i took it in and had it checked when i had new rotors put in and they said the strut was leaking. i thought it was b/s and ive been seaching this site for a thread like this forever. w/ my vic its front left. i plan on getting tokico blues very soon wheather its leaking or not, should i even worry about it or is it somehting other than the struts/shocks.
Old Sep 22, 2005
Whelan's Avatar
Rear sway bushing, Im assuming your talking about the point where the strut actually connects to the car. What do I lube it with I have some white lithium spray
Old Sep 22, 2005
bamb00's Avatar
you dont have stock wheels right?
check and see if wheel nuts are loose
Old Sep 22, 2005
Whelan's Avatar
Yeah stock 15"s with covers. I do need to get the wheels rotated once I get the new pads and shoes put on.
Just curious how a wheel nut would cause the strut to creak?
Old Sep 22, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Because you do not know for sure the SHOCK (its not a strut) is making the noise. When you have a few loose nuts, the wheel rocks on the studs and makes a banging noise I doubt thats the issue however. When its the right rear thats in question, unless you feel/see oil coming out of it, its probably not the damper. The exhaust could be banging something, there's a couple sway bar bushings that could cause some noises. If its a squeak, it isn't the damper, dampers go bang.
Old Sep 22, 2005
the sway bar bushing makes creak noise over bumps. I'm not sure what to lube with but just call a honda dealer and ask.
Old Sep 23, 2005
Whelan's Avatar
Thanks, Ill call them today and ask them whats up. Unfortunately I cannot bring it into them since I am a sales rep and cannot be even one day without my car. Not to mention the fact that for things like this they usually end up telling me that its nothing. Just like my window issue where they couldn't find the issue with it not going all down on auto and when I get in the car it sticks.
Old Dec 8, 2005
savedadogs's Avatar
savedadogs is an unknown quantity at this point
Hey Whelan,
Did you ever figure out the problem? I have the same exact noise now. Whenever I make a turn over an uneven surface or over a bump, I get a squeak almost sounds like grinding noise from my rear right back. Also starting from a stop, I hear some popping noise from the back also like you. Well, I have to take the car in on Monday to the dealer to fix another creak I have; the creak I have is from a bad fenderwall weld in the left front of the car.
Thank you.
Old Dec 8, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
^^^^hey yea, i have the same prob. any updates?
Old Apr 25, 2006
savedadogs's Avatar
Anyone come up with a solution to the popping from starting from complete stop?
Old Aug 4, 2012
plasmaok's Avatar
plasmaok is an unknown quantity at this point
Re: Right Rear Strut Creak and another Pop?
any one find the possible problem im getting a popping from my right rear when turning left over uneven surfaces would like to find the problem soon
fatih717171
Jul 25, 2016 06:22 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
SpecialRequest
Jul 7, 2015 07:52 PM
