- knocking?
- ATTN: 2001 Civic LX Sedan owners please reply
- Scratch in bumper
- Spring Noise What to look for?
- OMG.. what the hell is that noise?!?!?!
- need some help guys
- HELP FAST!!
- cruise buttons????
- Stock head light went out?
- Seat Cover Side Airbags?
- Grinding in 3rd w/ Shortshifter
- Weird Sound??
- rubber thingy under front bumper falling off
- noise?
- Tie Rod End Broke....
- engine light on HELP SOON
- 2k1, I need your help(2001+ Civic LX coupes)
- Water in Intake?
- Engine air flow not smooth...
- I have condensation in my Headlights
- help! door lock
- door panel popping off
- What does it mean...
- 2K1 Civic Problems....CRAP
- cig plug not working!
- CEL = exhaust
- Poor Highway mileage - may dump Civic
- Maint Req'd keeps on blinking then turns off?
- Manual Shifting???
- headlight bulb explode...????
- CHECK ENGINE LIGHT?? DIFFERENT SCENARIO
- Air Con problem
- Maint. req. light flashing on new EX
- Rust from wing installation
- turning back mileage
- Stock CD Player messed up
- Once again I've got problems with my gauges........................
- model DX w/out RPM guage . . .
- what the f@(k...always the same headlight
- cross threaded
- Rough clutch engagement/disengagement
- problems with the starter
- moderate shaking when going between 63-68mph
- exhaust problem!!!!
- Ive got gauge problems again!!! Need help!!
- 2 rev limiter???
- just hit a curb
- hard starting
- To anyone who has had the suspension noise....
- can a spc camber kit(front) fix this prob?
- Passenger window and rear windows
- You need to check this out
- I swear this car......
- Car bouncing
- HELP Interior lights going
- NOISES AFTER U TURN YOU CAR OFF? ANYONE?
- Steering WHEEL PROBS HELP
- My struts are shot
- Gas Cap Release
- DAMN TRUNK!
- AEM SRI ?
- SRS light question..
- Suspension concern
- Knocking from Koni's?
- Water And CAI
- Inside of rear window fogging up
- Trunk won't stay shut!
- high speed shakes on cold engine
- gauge needle problem
- speedometer stuck
- door ding
- FrieD clutCH!!!
- AIR VENTS
- Help, idle drops when engine cold.
- Fixing Rear Deck......
- battery indicator
- Driver's side door lock is dumb...
- cracked windshield
- Original transmission but motor swapped. Will this cause problems?
- i hear a poppin sound when i turn
- Engine Ticking
- Paint already peeling on new '02 EX...help!
- couple questions. please help
- Chipped/Cracked Paint
- failed state inspection for projetor lights
- Ticking noise when heater is on
- maint soon light timed at reg intervals?
- Front suspension clicks with left turns
- Does my engine sound normal?
- will alarm/remote start void warranty???
- aem cai hissing sound?
- Car got towed and now can't run
- Should I take my car to the dealers?
- Aftermarket Paint???
- to all my tall people
- Need To Know Where to Ground
- manual tranny problem 03...
- hit a curb and my camber is messed! HELP!
- Engine shake on start-up
- Rattling noise when going through water...
- Cracked Coilover Plate, Will Eibach Send Me Another One?
- maintenance required light question
- Headliner fit issue...
- trunk lock wont work
- Shifting to 1st
- how much for maintance
- mods lowering gas mileage?
- Horrible sound coming from car
- car wont start
- HELP PLEASE!!
- Engine Shakes and Check Engine comes on
- Radiator/Thermostat problem
- Help Adjusting Sensitivity On Stock Keyless Entry System
- What to do????
- power windows PRoBLEM!
- Clutch wear question...
- Goldline suspension problems....
- Returned Car?
- Raaarrrrrrrrr sound at Highway speeds
- '01-'03's STEERING WHEEL - Clank, Rattle,Clunk,Noise
- > > > Common Problems... < < <
- new bumper
- auto trans grinding??
- Noise when opening door
- strange noise, passenger door?
- Howling noise from tires
- is it normal the main req light blinks when i start my engine?
- i need some help! My car is overheating and its 30 degress OUTSIDE!
- HOW MANY OF THESE ARE WE GOING TO HAVE??
- Visor rattles...
- rpm's jumping
- Please help: noise coming from engine
- 02 cup holder lid
- ignition failure after updating support tools for emanage main unit
- finally got rid of my si coupe
- Flaking Paint on Bumper
- Gauge Needles Moving Randomly
- Car Battery Problem!
- Maintenace Required Light
- hmm strange.. help?
- Dome Light problem
- I'm averaging 15k km's between shocks
- battery dying!?
- obx b3 anyone know if it will pass smog?
- Injen CAI = right turn signal not working?
- Gas Mileage Sucks, part II
- URGENT HELP!!
- OK, HERE IS MY PROBLEM!!!
- scratching and knocking soun gd when i left the garage.
- "knocking noise"
- Clunking clutch?????
- Another horrible experience at the dealers!!
- strange sound from front passenger side
- Squeeking noise coming from THE transmission.
- Moonroof rattling - FIXED!
- Whine sound at idle!!
- Very strange problem...
- new front window seal!!
- Rice Krispies
- Ice chattering noise from back window area?
- New Transmission
- Windshield rock chip
- dnyamat fluke?
- G-Tech Pro Comp??
- Tailights fogged up...
- seat problem(not the rocking problem)
- dirty throttle
- Keyless entry & power door lock problem
- Problem with the Nokya bulbs
- bad struts!?!?!
- Seatbelt
- 2nd gear...grinding sometimes.
- Got '02 EX back from dealer today concerning rattling noise in engine
- HELP!
- headlight keeps burnin out
- blown tranny!!!
- Weird Noise coming from outside?
- Signal Indicator Problem!
- Fuel Gauge Problem!!
- Need Help Taking Off Air Filter Panel
- Rest padal screw broke!!!
- Fogged up Headlights
- "Jiiiii" sound from PEDAL when stepping on the brake
- Sidemarkers
- Brake Lights
- Neutral, Clutch Out, Wheels Turn... WTF?
- Wind Harmonics?
- notchy sound in first
- rubber under front bumper
- Some a$$hole hit my mirror...what should I do?
- Crappy Honda suspesnions...
- Generic front upper strut bar?
- Not passing smog after intake install?
- When A Broken CV Joint would be fun!! I need help:(
- Took '02 EX to dealer today for rattling noise in engine
- small part of wheel rusting
- WTF (tail light question)
- Speed Gauge No Longer Correct
- Question about reading a TSB
- MANUAL tranny FAILED, need help!
- Damn Hood!
- Factory Fog Light Owners - Broken lenses?
- Argh! My N1 Iz Rattling!!
- Broken Exhaust Hanger
- my baby just died at 12:45
- more power
- Couple Questions
- Sound between 1500-2000 RPM.
- question about a click/creaking clutch
- Dim Headlight Issues
- removing shift knob
- First Oil Change....
- My '02 EX, again, failed to start.
- Brake noise I guess?
- Maintanence required?
- ARRRGGG RIPPED BUMPER OFF
- Went in for service
- Anyone here have prob. with their intakes?
- dc tcs exhaust banging body frame
- Car wont start
- HEADLIGHT PROBLEM PLEASE HELP!!!!!!!!!!
- Damn MTEC Bulbs Burned
- air bag sensor (ASA)
- Broke trunk bolt
- grrr!! damn dents!
- Blown Strut? My Car Is Touching The Ground!
- weird noise during cold start
- Engine whine...
- Clutch *sproing* on 02
- Plastic Bag underneath car. BURN SMELL help pls
- Bad smell
- engine noise!!
- Trunk Ajar Light
- side molding removal? Not a repost
- Dealer says "It's Normal"....
- :( Tint problem [defrost/radio too]
- HELP PLEASE !!!!! REMOTE START
- aem shortram intake
- FOUND LEAK in trunk!!
- "POPPING" out of gear
- Shaking at around 60mph???Transmission or what?
- a new braking problem
- Does it wipe when you roll down your windows?
- Gauge cluster lights???
- Frozen driver-side wiper nozzle? :(
- Strange Exhaust Problem
- Types of problems ya'll have had with ur 7gen. Civ?
- Trans fluid ?
- Brakes???
- Chipping paint!!!!!!!!
