Dealer says "It's Normal"....
Old Dec 29, 2002
Freak's Avatar
Freak is an unknown quantity at this point
So I went to the honda dealer the other day they were really helpful and quick. First off my maintanence required light was blinking when I first started my car, then turned off. They told me that I had to reset everytime I did an oil change. THen I said this is the first time the light has come on, besides the 8,000 mile reset(I think its 8 thou), but I have done all my oil changes and have about 17,000 miles on my civic. He said oh ok... Then I asked about a little oil spewing in through the breather hose "PCV tube" (Thanks CIM) they said that this was normal, and then I asked if I should wipe it out, he said if I have the chance. I am kinda scared to let any oil get into my throttle body. ANy responses?
Old Dec 29, 2002
flotsamm's Avatar
A little oil is normal for the PCV system. What the PCV is suppose to do is allow unburned gases to return back into the combustion chamber. If its an eccessive amount of oil then I would be concerned.
Old Jan 4, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
if oil leaks are excessive that might be a sign of a backpressure inside the engine w/c is bad
Old Jan 5, 2003
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
yes that IS totally normal, its an emmissions thing, it takes gases(gasses meaning air pressure build up) in the crank case, and diverts them to the intake and combustion chamber where it can be burned and cleanly released into the atmosphere, often, a small amount of oil is in the tube, theres nothing to worry about.. PCV stands for Pressurized(?) Crankcase Ventilation
Old Jan 5, 2003
flotsamm's Avatar
PCV is positive crank ventilation
Old Jan 5, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
I thought our cars didn't have a PCV Valve???
But if we do where is it located on the car?
juicetayne
Sep 30, 2015 11:02 AM
brash99
Sep 29, 2015 08:42 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
260000milesgoal
Sep 25, 2015 07:41 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
