moderate shaking when going between 63-68mph
Old Feb 17, 2003
SiuSiu's Avatar
SiuSiu is an unknown quantity at this point
okay i have got into an accident last weekend. to make a long story short..repair shop did an alignment and replaced the front bumper + driver side fender. no internal damage. after i got my ride back my steering wheel shakes moderately going 110-120km/h. shaking disappears after 120 and dose not shake before 110. what seems to be the problem? the alingment is my guess. the shop probally did'nt know the numbers for the new civic camber adjustments?
Old Feb 17, 2003
wing0's Avatar
wing0 is an unknown quantity at this point
maybe...or the tires need to be balanced?
Old Feb 17, 2003
MaxPSiLX's Avatar
MaxPSiLX is an unknown quantity at this point
Try A)swapping the tires from one side to the other, and if that doesn't work B)balance the front tires. Did you run over anything or were you hit directly in the suspension?
Old Feb 17, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
u got after market rims right? get the hub rings...10 bux will fix ur problem.
Old Feb 18, 2003
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Yeah, most likely it is an easy problem to fix...check all the tire pressures to make sure they all equal 30 psi, then maybe have the tires rebalanced....
2Hottie
Old Feb 18, 2003
FALKEN's Avatar
Civicforums Junkie
hub rings and balance.
mgrantaz
General
May 2, 2022 05:40 PM
Solo Flow
Oct 4, 2015 07:52 AM
Tedverseti
Sep 29, 2015 05:41 PM
SolidHollow
15
Sep 13, 2015 11:18 AM
rainman15
Sep 6, 2015 11:10 AM
