headlight keeps burnin out
I Am The Chosen One
my drivers side haedlight keeps burnin out, i have had to replace it 3 times in the last 4 weeks. i have installed nothin new, and have nothinn runnin off of any lighting wires. anyone have an idea what could be causing this, its pissin me off and the guy who keeps replacin my bulbs.
Quote
[hr]Originally posted by: profurious
my drivers side haedlight keeps burnin out, i have had to replace it 3 times in the last 4 weeks. i have installed nothin new, and have nothinn runnin off of any lighting wires. anyone have an idea what could be causing this, its pissin me off and the guy who keeps replacin my bulbs.[hr]
2. The light bulbs just plain suck (cheap brand)
3. He touched it with his fingers (oil kills the bulb)
4. Your wiring harness can't handle your bulb
Answer is simple....
1. Buy PIAA or MTEC bulbs
2. Clean the glass with windex and tissue before putting it on
3. Enjoy...
edit: You can find MTEC bulbs on ebay starting $3... they are as good as PIAA's
I Am The Chosen One
1. lights are exact same wattage
2. they're sylvania silverstars, so they're not cheap
3. i installed them so there's no oil cause i wear latex gloves when doin any work to my car
4. the wiring harnes had no problem for the first 5 months, and now its all of the sudden
their has gotta be somtin else, i wish i new.
From: San Diego, California, USA, Northern Hemisphere, Earth, Sol System, Spiral arm of the Milkey Way
Quote
[hr]Originally posted by: 666
I have found no matter what brand aftermarket bulb it is they always seem to burn out.
[hr]
Latex burns too, even a few molecules, just be careful and dont touch the glass, even with gloves on, if that doesnt work, check the wiring.
i think ur problem is that theres oil on the bulb. when u change bulbs always wipe the buld with rubbing alcohol NOT WINDEX windex contains ammonia and other stuff that leaves residue on the bulb. rubbing alcohol leaves no residue and works perfectly everytime. also be sure not to scratch the glass on the bulb. hope this works
i had silvania silverstar and i have a problem wiith passenger beam the DRL light come on but not at the same force compared a the driver side and the low or high beam not come on the fuse burn and if i replace the fuse im opening the light and oppssss the fuse burn right now
driver side no problemo what the f**k?
I had some APC superwhites, yea big mistake, burned out in 6 months, now I have silverstars, no probs yet I switched em when 1 APC burned out about hmmm? 2-3months ago. I had silverstars in my old car and had 1 burn out, just replaced the one and it was fine, but I didnt have the car for over a year after I put the new one in, so who knows maybe my silverstars will eventually die too.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
