Engine whine...
Old Dec 31, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Engine whine...
After 16K miles on my Civic the engine has started to whine badly. Before it was so quite...
Any ideas? I don't know how to decribe it other than a whining sound. It increases/decrases with the rev, but stops when at a steady RPM.
Old Dec 31, 2002
solar's Avatar
solar is an unknown quantity at this point
Could be lots of things but first, check your power steering fluid, if its really low then you have a leak. But if the fluid is fine then try to pin point where the noise is coming from. It could be a power steering pump, A/C compressor, water pump, automatic transmission, etc. Then reply with more info, or take it to the dealer.
Old Dec 31, 2002
flotsamm's Avatar
Could be altenator also..
Old Jan 2, 2003
xe2k2's Avatar
xe2k2 is an unknown quantity at this point
Quote
[hr]Originally posted by: solar
Could be lots of things but first, check your power steering fluid, if its really low then you have a leak. But if the fluid is fine then try to pin point where the noise is coming from. It could be a power steering pump, A/C compressor, water pump, automatic transmission, etc. Then reply with more info, or take it to the dealer.[hr]
I bet my money on a a/c compressor. My previous car made loud whine, sounded like a loud turbocharger spooling, but sound slowly disappeared with steady RPM(like hwy driving). but that annoying sound returned when i hit the street. When my mechanic took off the a/c compressor belt sound disappeared completely, granted i had to drove w/o ac for that summer but it was worth it.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
