engine noise!!
Old Dec 30, 2002
SiVeloz's Avatar
SiVeloz is an unknown quantity at this point
engine noise!!
Hey guys,
I have a 2002 Civic Si (Ex in US) I have about 29000km on it. When the car idles and i rev it to about 1500rpm and let go of the gas i can hear rateling noise comming from the engine while the rev goes down... Only mod to my engine is a short ram intake... I didn't notice any difference in performance or anything.. jost wondering if any of you guys heard of this before.
Old Dec 30, 2002
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
Could be this: excessive play in camshaft
Old Dec 31, 2002
I had the EXACT same problem. To save you the trouble of searching for my fix, the intake is most likely causing the rattle. The filter sits right on the top of a metal mount. When it shakes, the filter causes a rattle sound. I just put a piece of cloth underneath the filter to stop the noise. If you want to test this, just put your car in reverse or let it idle on an incline. You can see the filter shaking when it makes the noise, and pressing down on it causes the rattle to stop.
Old Dec 31, 2002
SiVeloz's Avatar
alright thanks guys...
I'll check tonight to see if it could be my intake... If not il get it check by Honda for that excessive play in the camshaft
Old Jan 2, 2003
Pinoy3LeR's Avatar
Pinoy3LeR is an unknown quantity at this point
if its not the intake,the rattling would be coming from your valves,it means that their clearance must be adjusted
Old Jan 2, 2003
SiVeloz's Avatar
could it be that my valves clearance must be adjusted and my engine only has 29000 km??
Old Jan 2, 2003
Pinoy3LeR's Avatar
yup,try to look at yor manual when it is scheduled to be adjusted,valves tend to rattle when they are a little loose,but w/ a simple adjustment the rattling sound will be gone
hope that help's[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 3, 2003
Free7civicex's Avatar
Free7civicex is an unknown quantity at this point
Is it possible for a new car to have loose valves. My '02 EX has a little over 3000 miles and when I accelerate I can hear (with my window down) a rattling sound coming from the engine. It almost sounds like a diesel. I took it to my Honda dealer and they couldn't find anything wrong. At the time though I didn't know it could possibly be loose valves, so I didn't ask the mechanic to look at them. I'm pretty sure they didn't check the valve on their own because they only looked for loose engine parts (such as the heat shield) and they had my car for less than an hour.
Should I take it back to the dealer and have the valves looked at under warranty? I don't want the service guys to think I'm an idiot and tell me that this isn't possible on a new car. If it is a possibility though I will take it in.
Old Jan 3, 2003
Pinoy3LeR's Avatar
it seems like its too early for your valves to loosen up,but have it check by your mechanic,the rattling sound of the valves are normal,but if its too loud,better take it to your honda mechanic[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 3, 2003
Mbow's Avatar
Quote
[hr]Originally posted by: gearbox
I had the EXACT same problem. To save you the trouble of searching for my fix, the intake is most likely causing the rattle. The filter sits right on the top of a metal mount. When it shakes, the filter causes a rattle sound. I just put a piece of cloth underneath the filter to stop the noise. If you want to test this, just put your car in reverse or let it idle on an incline. You can see the filter shaking when it makes the noise, and pressing down on it causes the rattle to stop.[hr]
I'd almost bet the trust fund that this is your problem. Tighten her up and try to put something to keep the intake from vibrating.
bokogabe
May 21, 2015 09:27 PM
CurryBomb
May 8, 2015 10:16 AM
smmahan
Apr 15, 2015 08:17 PM
silvervtec01
Dec 9, 2001 08:50 PM
TAZZ
Dec 5, 2001 09:35 PM
