HELP FAST!!
Old Feb 25, 2003
Blckcivic01's Avatar
Blckcivic01 is an unknown quantity at this point
HELP FAST!!
ok lastnight i noticed that my headlights would fliker and then tonight while i was driving they just cut off then like 10 mins later they came back on and now they went back off and arent coming back on.... but for some reason my high beams still work..... any idea what may be wrong??? its just my low beams that dont work.... high beams are fine...
Old Feb 25, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
might be the wires...or ur bulb is not tight....open ur hood and check it out, see if everything is in place
Old Feb 25, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
What brand/model are these bulbs? I think your bulb is just wacko.
Old Feb 25, 2003
i got the xenon blue bulbs
Old Feb 26, 2003
JohnnyLee's Avatar
7thgen guh chee
My Matrix bulbs use to do that for a bit then dies a couple weeks later.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 26, 2003
what would i look at if it was the wires?
Old Feb 26, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
Your low beam may be just touching the connection inside the bulb. Check and see if you hear anything when you shake the bulb. Much like a regular light bulb. When it is burned out, you hear a CLINK sound. Try to get PIAA bulbs instead of cheap Xenon bulb. In the long term, it will save you more money than to keep buying cheap bulbs.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 26, 2003
i put my stock bulbs back in and the low beam still wont come on i guess ill play with the headlight and try and see if anything i loose
solarpunk70
Apr 12, 2016 11:43 AM
IronFist
Sep 25, 2015 07:13 PM
meicalnissyen
Sep 25, 2015 12:12 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
jonwalden68
Aug 27, 2015 12:07 PM
