headlights and gauge lights going from dim to bright, alternator?
Old Sep 22, 2015
IronFist's Avatar
A bit ago my dash lights started going from dim to bright really fast. WHen I took it to a few places they tested it and said the alternator was the problem. A shop I took it to said it was not the alternator and it was fine. They said it could be bad battery connection however they wiped off the cables and gave me a new battery and said that might fix it. The problem is still happening. It doesn't happen consistently, but I notice it at night periodically.
This subforum with ICE appeared to be the exact place to tell my question.
Does this sound like a specific issue?
Old Sep 22, 2015
Re: headlights and gauge lights going from dim to bright, alternator?
Holy crap.
How much of a difference do you notice in your headlights/gauges? Voltage does fluctuate quite a bit during normal operations (something along the lines of 11.4-14.2V) so a bit of dimming is normal. Well, at least that I've noticed in the 13 years of owning my car.
Old Sep 22, 2015
I'd put a volt meter on it and see what the numbers are as it pulsates....note voltage highs and lows.
Yes voltage going up and down is normal with charging requirements, speeds, and electrical loads (the ELD system), but rapidly pulsing does not sound right.
I'll guess alternator.
Old Sep 22, 2015
I missed the really fast part. I maintain that I can't read or write..
Old Sep 25, 2015
IronFist's Avatar
Hi xRiCeBoYx
A few stores have said it's nothing.
A few stores have said it's the voltage regulator.
A few stores have said it's the alternator.
I got some of those papers with the diagrams on them and they show everything is good.
A different places said it might be a bad ground.
One place in particular said it was a bad voltage regulator. Another place said it was the alternator.
The car starts fine. THe dash just gets dimmer and brighter really instantly. It doesn't happen every trip. I drove from illinois to california and it started like halfway through. CHanging the dash display doesn't fix it, they still continue to change based on how bright I Have it set.
Old Sep 25, 2015
Effectively, those are all the same answer.
The voltage regulator is inside the alternator.
You aren't going to change one without changing the other unless you want to try to split the alternator open and gut it.
We have a rebuilder in my town that uses the cheapest parts for rebuilding starters and alternators.... I've seen your exact complaint several times.
Printout from a tester? LOL
Honda forces us to use those dang things.....I've got some opinions but I better not say a lot about it here:
70% accurate is just as good as 100% accurate, right?
That would be a sh!tty record if you were a sniper.
stryder12
Jun 30, 2015 08:33 PM
werdnahall
May 17, 2015 11:37 AM
shaejb15
Apr 26, 2015 07:44 PM
civic_gt
Apr 19, 2015 08:15 AM
GhettoCivic
Nov 12, 2001 03:15 PM
