Ive got gauge problems again!!! Need help!!
Old Feb 17, 2003
Jodster's Avatar
Post Whore General
OK heres the story. I use to have indiglo gauges on my vic. They burned out, so I had to take them off. When they were on, the tach would stick from time to time due to the gauges being really thick and not tape down all the way. Now I'm back to my stock gauges and I'm having the worse time with them. The tach was stcking bad, so I taped in down. It didn't fit it. And now my tach and speedometer is stick bad. I Whats the deal? The rings around the needles are in and I taped the faces down. What is the problem?
Old Feb 17, 2003
DaPipeLayer's Avatar
AAAAHHHHH!!!!!
DaPipeLayer is an unknown quantity at this point
Were you rough with the needles when you put the gauges in? Are you sure that they are COMPLETELY FLAT on the surface with absolutely no air behind the gauges? If you say the needles sticked while they were off, you possibly could of have not gotten all the tape of causing the needles to stick.
Xuhme
21
Aug 7, 2023 03:40 PM
Bruce.Ringler
Jun 18, 2015 08:12 AM
brian257
Jun 4, 2015 08:17 PM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
