Frozen driver-side wiper nozzle? :(
Old Dec 26, 2002
FurBall's Avatar
FurBall is an unknown quantity at this point
This is the second time it's happened to me...
My driver side windshield nozzle has frozen up!
It snowed this morning here in Toronto, and it's only like...-4C (not that much below freezing), and well, there's no snow or ice on my hood as I wiped it off, and when I sprayed, nothing came out of the driver side nozzle! My nozzles are stock BTW...
Another time it was colder, like -15C, and it did the same thing. Only the driver side. When I lifted the hood, I saw BUBBLES in the nozzle tubes. Is this supposed to happen??? Or do I have a leak somewhere? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
I've checked the hoses and there doesn't seem to be a leak. I'm using "Canadian Tire-brand" stuff that's green in colour. It's supposed to be up to -40C plus detergent in it...
Only way around this issue is to pour warm to hot water on the nozzle, and after 5 seconds or so, it's fine.... I'm thinking just the holes are clogged with ice, but then, why the hell only driver side? Shouldn't the wiper fluids clean that up?
Anyone else have this issue? Anyone else have any ideas why it's happening?
Old Dec 26, 2002
1955's Avatar
stripe a strand of speaker wire and use it to clear from the opening
Old Dec 26, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
That's happened to me before on my previous car, not my civic. If it freezes up, it's almost always due to bad fluid. I had to flush out the old stuff by using it all up and then put in new stuff. (note: I used to live in Ottawa)
Old Dec 27, 2002
666's Avatar
666
666 is an unknown quantity at this point
Thats happened to me before too. I found out it was the windsheild washer fluid that was freezing up in the hose because I was not using the right temperature grade. That may be your problem, look on the bottle and see what it gives for a temperature rating.
Old Dec 29, 2002
Macko's Avatar
Macko is an unknown quantity at this point
mine never froze up before.... in fact it shoots right through the layer of snow (if it happends to be any) on the nozzle...and i use the crappy tire brand blue fluid.. it's just winshield washer fluid brands don't matter.... in fact i switching to the brand my wokr sells and is cheaper... the worst thing you do is dilute the washer fluid.. i knew some idiot who poured in H20 into the fluid resivior in his type R and it sure as hell froze over... LOL..[IMG]i/expressions/laugh2.gif[/IMG]
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
RSJ
Aug 13, 2016 01:06 PM
MichaelLW
Sep 14, 2015 07:15 AM
Dsmak
Sep 10, 2015 08:30 PM
