Rattling noise when going through water...
Old Feb 3, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Hey guys,
I am having a really weird problem with my car. It seems as though whenever I go through any significant water (big puddles, watery streets...etc) I hear a rattling noise coming from what seems to be the front right wheel somewhere, or the engine bay. It almost sounds like something is hitting up against the wheel or just flopping around. It will do this for awhile then if I stay clear of water for about 5 minutes it goes away. Maybe coming back about 10 min. later or something like that. I have a AEM cold air intake with bypass valve. However I talked with some of my buddies and they said not to worry as I probably am not taking in water through my intake. I was just worried that the fellas at my performance shop didn't install the bypass valve properly. So what is all your opinions on this?
Old Feb 4, 2003
Craig's Avatar
Craig is an unknown quantity at this point
I had the same problem and it seemed to only occur when I was braking.
Old Feb 4, 2003
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
this has been posted before but it is the exuast pipe. when it gets wet when its hot it vibrates againist the bottom of the car! honda will fix it if its under warranty and has stock exhuast!
Old Feb 4, 2003
Sivion's Avatar
Resident Tough Guy
I have a aftermarket exhaust as well. An Apexi one. It also didn't always do this. I have had the car a little over a year and it started about 2 months ago. Also, had my intake and exhaust for awhile too before that. Although I don't recall going through any major water till abuot then cuz it was so dry. Anyone else know what might be going on?
Old Feb 5, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
it's your exhaust piping. Mine does the exact same thing when i go through water. Having looked under my car, the pipe is not touching the body piece but it's pretty close. Once water hits the pipe and it starts going bonkers, it starts rubbing on the car. Try messing with the exhaust pipe and get it further away for the body and/or pad it with something.
sorry for the long sentence [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 6, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
yea its the post about the dc tcs, thats me. but if this happens with the oem cat, honda can fix it by puttin clamps in and clamp that sucka tight. but if u have aftermarket ones, u need to take ur car to an exhaust shop, have them clamp the exhaust or something to stop it from banging against the bodyframe, cost $50 for me to do it
Old Feb 12, 2003
Sivion's Avatar
Resident Tough Guy
Ok, that's all good. Thanks for the info. But eh, I tried to explain this to my performance shop and they said that it does not make any sense to them if it happenes when it's wet and not dry. Anyone have an in depth reason why this would happen? (technicalities?) That would help in explaining what I need for them to do exactly. Of course since they have not done any other car like mine for exhaust yet, they didn't ever hear of this. Thanks again!
Old Feb 13, 2003
BIGLIMPDOG's Avatar
when metal is hot and you splash cold water on it what happens? it produces stem and causes a reaction which causes friction and friction causes the hot metal to vibrate! So if its to close to the bottom of the car it will vibrate againist something which produces sound and thats what you are hearing! TECHNICAL ENOUGH?[IMG]i/expressions/laugh2.gif[/IMG] every car has this issue but the exhaust is not close enough to the body to hear it!
Old Feb 13, 2003
i'm positive its the pip bangin the frame
Old Feb 13, 2003
Sivion's Avatar
Resident Tough Guy
Excellent, thanks fellas [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
junkyardguy
20
Sep 6, 2015 10:07 PM
cja3455
Aug 24, 2015 06:20 AM
Yazan93
Jul 14, 2015 08:56 PM
fvckbg
Jul 7, 2015 07:08 PM
