Broke trunk bolt
Just Be
Broke trunk bolt
I was trying to adjust the latch on my trunk, and put it on the lowest setting to stop rattling but the trunk did not shut. at all. so then i put it back to normal, and when i tightened it, the bolt head snapped off. So now i have one bolt holding it on... should this be fine? the rest of the bolt is stuck in there, how do i go about removing it?
If you cant get a bite on the bolt with any other tools, maybe try using a screw extractor. Here's a link: http://doityourself.com/store/screwextractor.htm
Basically all you do is drill a small hole in the bolt, tap in the screw extractor and use a cresent wrench and back out the bolt.
sbi
Sep 2, 2015 07:44 AM
jimmy23
Aug 31, 2015 10:35 PM
honda.lioness
Aug 21, 2015 02:36 PM
WaryDriver
Aug 8, 2015 05:08 PM
muttleytm
Jul 14, 2015 05:31 PM
