i need some help! My car is overheating and its 30 degress OUTSIDE!
Old Jan 29, 2003
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
well my car has overheated twice in the last month. I filled drained and filled back up the resiver (sp) and the radiator and it did it again last night. Now this is whats new to me, my car will not ever get hot in motion and i can not make it over heat, it will only do it when im stopped and it doesnt take long once it starts to get hot. So i was thinking my thermostat maybe be sticking, so i touch the hoses and they both upper and lower have water in them when the car is running, the upper hose was hot to touch but not burning hot even though my temp gauge is reading smoking hot! The lower hose that connects to the themostat was cool to the touch. I can not find a leak anywhere but i do lose a little water but i think that it steams away when it gets hot and it will come out of the overflow. If it is a thermostat that sucks because no one carries it for my car down here in texas that i can find, and if i have to get it from honda im sure it will be expensive! I need a little help if anyone knows anything at all. I also check oil to make sure i didn't have a blown headgasket and i dont!
Old Jan 30, 2003
solar's Avatar
solar is an unknown quantity at this point
Is the radiator cooling fan coming on? Sounds like it not working because if your moving air is being forced though the radiator, but when you are sitting still no air is passing through the radiator. Which would cause your car to over heat in any outside tempature.
Old Feb 2, 2003
BIGLIMPDOG's Avatar
i checked that and they both come on but they seem to be taking longer to come on than normal! when i run the ac which kicks on the fans it does seem to cool back off! how do i fix when the fans come on?
Old Feb 3, 2003
solar's Avatar
If the car is under warrenty take it to the dealer, because there are so many things involved, its hard to figure out what wrong with your car without looking at it first hand.
Old Feb 3, 2003
BIGLIMPDOG's Avatar
my car has no warranty!! 51,000 miles!!! Im so screwed!!!!!!!!!!!
Old Feb 3, 2003
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
take it to a local shop like midas, or somewhere like that. they will inspect it for free. once you know the problem, you can find out how to fix it. and see how much it would cost to have it done, or find out how to do it yourself. i know how mad you must be...sorry bro[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Feb 3, 2003
SilverCivSedan's Avatar
SilverCivSedan is an unknown quantity at this point
Water in the radiator?? I always use antifreeze
Old Feb 3, 2003
solar's Avatar
Quote
[hr]Originally posted by: SilverCivSedan
Water in the radiator?? I always use antifreeze[hr]
I hope you don't use "straight" antifreeze, you should use a mixture of water and antifreeze, your owners manual will tell you what the proper mixture is. Using straight antifreeze with no water at all will cause the antifreeze to foam up and it will make your car over heat because there will be no circulation. Of course this is if the cooling system has nothing but antifreeze with no water mixed with it. Like if you drained the system and just replaced it with starght antifreeze.
If you are having problems with leaks and over heating water is the thing to use, until you fix the problem, because antifreeze is to expensive and its messy and it keeps coolant from going into the storm drains.
Old Feb 4, 2003
BIGLIMPDOG's Avatar
thanx for all the help guys and it will overheat with just antifreeze! speaking from experience!
Xuhme
21
Aug 7, 2023 03:40 PM
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
jessicakaybby
Apr 20, 2015 12:11 PM
deus-ex
Apr 13, 2015 12:29 PM
