PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Windshield Wiper Reservoir Repair
  2. heyyy!!!!! newb here, introducing himself with some questions
  3. Fog Lights
  4. i cant get the fly wheel off
  5. here is a new one for ya all...
  6. civic k20/k24 swap
  7. wet floor
  8. Confused
  9. Weird noise under the car (driving in rain)
  10. stupid black things under car
  11. Power Windows
  12. HELP!!!signal stays on when headlights is on?
  13. Rough running
  14. car running hot
  15. OEM fog light switch wiring
  16. ac problem
  17. My Civic Model? Big Mystery
  18. CV Boot
  19. Rough Idle just appeared
  20. Engine shaking and idling at 2K, jerks when shifts(auto) HELP HELP!
  21. HID Help
  22. Suspension Problem
  23. Funky Idle, No CEL
  24. Need Help/Suggestions
  25. Another ABS Light Question; Please Help!
  26. Motor mount cracked in half
  27. did anyone have power door lock die on them
  28. need help to take out the console
  29. Cars
  30. how do i put my battery back to stock location??
  31. FLB Fuse blowing
  32. toot toot dosent work any idea why
  33. odd smell
  34. ECU Diagram anyone?
  35. 2001 civic cluster (need help, used cluster gauge)
  36. Civic Making Loud Noises
  37. CEL came on=== tranny slipping
  38. sputtering civic
  39. Nasty sound and violent feel... is this the axle?
  40. Need Some Fuel Help Yall!
  41. Do I need to use only Honda sparkplugs?
  42. Help! Car Won't Start!!!
  43. Water Leak
  44. Paint is flaking off!
  45. Door locks kinda
  46. Auto Tranny Shift Q's
  47. Took car in to Dealer to get fixed *help*
  48. another window thread
  49. Response from Honda mechanic about Honda specific fluids and our transmissions
  50. Tranny Problem in the works, maybe?
  51. Vtec not Working Help..
  52. 03 getting real hot
  53. Update:D17A2 head swap done... but major problem... plz help!!!
  54. airbox nuts/bolt problem
  55. Motor Oil on Spark Plugs
  56. ear piercing noise
  57. window problem...
  58. Aiming headlights
  59. Help w/ power window regulator
  60. 2001 Civic Immobilizer Bypass 555h or 555i
  61. Most annoying rattle ever...moonroof
  62. Need help finding a part
  63. stripped strut tower nuts and bolts..NEED HELP
  64. Sedan '01 passenger power window issue
  65. Tint problem/question...
  66. Ho d00ds, my new car
  67. Have a problem..Need Help
  68. Concern about car
  69. HELP ME! Whining noise while driving
  70. Sticky Shifting
  71. Anyone know how to remove the silver surround around the shifter?
  72. problem w/ my hazard lights
  73. Injen intake broke!!! need advice
  74. very strange problem with my friends 7thgen
  75. help! 1st time manual transmission fluid change
  76. Trunk Wont Open?@ :(
  77. hrm....
  78. Tranny problem
  79. Anyone have a PDF Helm's on 7ths?
  80. Does the Hazard button light up?
  81. Popping Noise from front of right rear lower control arm
  82. Battery light
  83. Horn doesn't work.
  84. Sunroof Rattle
  85. Brake light & Oil Light
  86. Engine noise
  87. srs light on nd tried the diy for it...HELP!
  88. Dealership Shop Service Quality List
  89. auto tranny shift issues w/ error code
  90. Trash bag melted to exhaust!
  91. OBDII Code
  92. Window tint issues
  93. Spark Plug Help!!!!!
  94. Strut Spring Perch Problem: HELP
  95. Strut Spring Perch Problem: HELP
  96. Locking Wheel Nuts
  97. Low beam problems
  98. Door Sensor
  99. K20a injector
  100. Some kind of Oil problem?
  101. what did i snap??
  102. Intake.....
  103. Rear View Mirror broke off
  104. Short Throw/ Exhaust Issues
  105. Bolts for stock airbox/resonator... Help!
  106. Battery Light
  107. header CONFUSION =/
  108. clutch engagement
  109. Help me find a new tranny please!!
  110. Cylinder Head weight?
  111. tranny whines
  112. Headlight out followed by buzzing sound....
  113. List of common problems with 7th Gens?
  114. A/C Condenser falling apart
  115. is this normal
  116. Heat problem...AARRRGGG!!
  117. Squeek Squeek...
  118. SRI and engine temperature guage
  119. transmission problem help?
  120. Steering wheel not returning to middle?
  121. Spark Plugs 02 Civic Ex
  122. Car makes metalic scraping/creaking sound
  123. what up
  124. Power Window- Parts need to fix
  125. got a problem.
  126. Loud belt noise
  127. What up
  128. Windsheild washer fluid sometimes squirts out by itself
  129. My car doesn't start sometimes....
  130. Help!!
  131. Scrappy Sound Near Right Wheel or Engine bay
  132. EX owners with AEM shortram intake
  133. UGH! Frame Problems
  134. New to the site and need some serious help on my 2001 door locks.
  135. SRS Light
  136. spring help
  137. Trouble installing speakers - door panel does not snap shut
  138. Clutch Friction Point Changing
  139. how much should I expect to pay for a new alternator?
  140. feul (gas) door release broken
  141. Check engine light won't stay off!!!!
  142. check engine light is on.............
  143. Side airbags or no?
  144. Power steering froth
  145. Pulling with a spare normal?
  146. Winding noise ???
  147. Gas tank gauge problem
  148. AC Not Functioning
  149. Anyone have trunk spring rattle?
  150. Steering Wheel Problem!!! HELP!!!
  151. Wipers and wiper fluid not functioning...
  152. finding a rattle, need a favor
  153. light on alarm doesn't work , pls help
  154. Buzzing noise coming from instrument cluster
  155. roof liner sagging
  156. pre-problem diagnosis
  157. squeaky clutch pedal
  158. Messin' with electrical sys, now car won't start
  159. 02 Ex Radiator Support
  160. Manual Transmission Problems in a 95 Eclipse
  161. Driver chair rock back and forth
  162. Car Wont Start! help
  163. Need Help... Bad Idle.......
  164. Headlight Issues
  165. front wheel hub & bearing
  166. rpms stuck at 2k.
  167. Changed Headgasket Car turns but wont start
  168. led turn signal Load Resistor kit
  169. Gauge cluster problems
  170. Problem when starting car
  171. Noise coming from acceleration above 2K
  172. grinding on snow and ice
  173. Road Noise Fix
  174. what to do ...
  175. need help removing a bolt
  176. Sputter at 3500rpm
  177. wierd suspension / steering problem
  178. Vibrating noise in the left wheel area when I turn my wheel
  179. Seatbelt Light Door Dinger
  180. CRAZY wheel shaking!!
  181. rain in hawaii = passenger side flooded
  182. Slight noise cant figure out
  183. f*cking dealerships
  184. Locating the ECU
  185. wheel noise/vibration
  186. How can i install headers w/ out CEL?????
  187. unsure problem
  188. Stopping pebble noise under car
  189. Door Locks
  190. Bumper Grille
  191. Type B Skirts
  192. k swap imobilizer question
  193. Projector headlight problems..
  194. Axle Problem? PLEASE HELP
  195. Car caught on FIRE
  196. Having overheating problems
  197. No alarms
  198. dash light and parking light flash for alarm
  199. changing engines
  200. Annoying squeaking sound coming from rear window
  201. Winding Noise When I First Start Car?
  202. Horn and 4-way flashers are ONLY things that work!!
  203. Turning RUBBINg Noise, PLEASE HELP!!!
  204. REmoving wheel cylinders
  205. small crack in windshield help
  206. Keyless Entry Question...Need some Imput.
  207. Help P0122 TPS Sensor
  208. Possible Transmission Problems with 02' Civic LX. Help please.
  209. whould this be a good idea?
  210. No climate control lights, and now no gauges, but icons light up..
  211. car over heated?
  212. exhaust rattle
  213. Axles being dumb help...
  214. Error code problem P0102 Need help!!
  215. Check engine light
  216. o2 sensor issues
  217. Fog Light Issues
  218. help
  219. ahhh bumper plastic thingie
  220. rear speakers?
  221. Vtec + Engine Light
  222. warranty question
  223. heat problem??
  224. replacement fog light help
  225. check engine light..bout 1000 codes
  226. Coolant splatter
  227. 1998 Civic EX whistling noise
  228. broken motor mount
  229. TURN SIGNAL! turn signal.
  230. someone help plz!!
  231. engine is vibrating and acting really funny
  232. still reset ECU?
  233. Gauge Faces flicker!
  234. Strange noise coming from engine bay...
  235. tech question...
  236. My car is all messed up. cuz header
  237. 02LX door fabric - engine mount - leaking struts
  238. Stock air box
  239. 01+ Civic "Manufacturer" Steering DEFECT
  240. Wet floor?
  241. right (passenger) side turn signal
  242. Vtec Light prob
  243. cracked airbag cover
  244. Look What Happen To My Car This Morning
  245. is honda telling the truth?
  246. Tranny or Engine Mount?
  247. help!!!!!!!!!!!!!!
  248. *sighs heavily* help plz!
  249. Parking light...what kind of bulb
  250. cant drive in the rain
