My car doesn't start sometimes....
Old Mar 18, 2006
Si Gurl's Avatar
Si Gurl is an unknown quantity at this point
hey everyone! sooo i got into my car today and it wouldn't start! i tried 3 times and finaly the forth time it started... This has happened in the past before in cold and hot weather? does anybody know why this is happening and what i can do to fix it thanx guys
Old Mar 18, 2006
EM2jdm's Avatar
EM2jdm is an unknown quantity at this point
the first thing i would check is if the battery terminals are not all corroded, then if that is the problem check if the battery is still good, then check the alt. see if the is that good or you could take your car to autozone or a shop to let them do a electrical test.
Old Mar 19, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Check your grounds and the cables on your starter. Jiggle um see if they are loose. Tighten if need be.
Old Mar 19, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
clean the metal tips? on top of the battery with sandpaper, sometimes that can cause it not to start, if it still doesnt start after than i'd check the starter but its way too soon to get that checked out.....gas pump prolly?
Old Mar 19, 2006
battery, grounds, plugs, and plug wires. Get some regular copper plugs for $8. I know on my car using iridium my car wouldn't start at least once a day, just kept cranking. Switched to copper and it starts up 95% of the time.
Old Mar 19, 2006
Si Gurl's Avatar
Thank you i will try that!!!!
Old Mar 20, 2006
GA_Teg's Avatar
GA_Teg is an unknown quantity at this point
Not sure but mine will not start sometimes, for some reason it will not read the key. Just take the key out and put it back in and it starts fine, kind of weird.
Old Mar 20, 2006
Sypher's Avatar
Sypher is a jewel in the roughSypher is a jewel in the roughSypher is a jewel in the roughSypher is a jewel in the rough
Does the car have an imobilizer? It could be a problem with either the chip in the key or the car's imobilizer problem
mistermenphis22
Apr 3, 2016 08:06 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
tattedlariat
Apr 17, 2015 03:26 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
