2001 Civic LX: Shoddy work cause of check engine?
Old Apr 19, 2015
mistermenphis22's Avatar
mistermenphis22 is an unknown quantity at this point
Bought the car cheap with a blown head gasket. Fixed it for cheap. Cleared codes and it passed smog. Codes cleared were p0171 and P0453.
Check engine came back on with the same codes
but the car runs fine and starts up fine. Really don't notice symptoms except a funky fuel gauge that sometimes reads 1 or 2 units higher or lower.
I installed some speakers in the back recently and I noticed an abomination of wiring with what appears to be a on/off switch. This is the plug next to the fuel filter cap thing. I dont know what the wiring does. All I know is that it doesn't look like that.
Car had new oil, sparks and o2 sensor changed. So that rules them out.
Below are some pics. This is under the rear seats.
http://m.imgur.com/MwkNSfO,yLpF4Wh,H...oMkwkz,ccXhyJQ
All help is appreciated. I have no idea what I am doing. I know how to do basic maintenance and that's it.
Old Apr 20, 2015
GolNat's Avatar
Prelude Owner
Re: 2001 Civic LX: Shoddy work cause of check engine?
The switch looks to be a fuel pump cut off switch. This may have been installed for increased security. Generally the switch is hidden so thieves can't find it.
Do the wires go to the pump? It's hard to tell in the pics.
Old Apr 20, 2015
Stock 99's Avatar
The shoddy wiring isn't the cause of your check engine codes.
Golnat is correct and that's a kill switch for the fuel pump (even though I can't exactly see the wiring). It's in your best interest to either fix it or remove it. The 12v line has been cut to the fuel pump and the switch has been inserted. So in the off postion the fuel pump will not function. Either remove the switch and wires and reconnect the 12v line with solder (not butt connectors, not electrical tape) or keep the switch and just wire it properly by soldering all the connections.
Old Apr 20, 2015
I didn't open up the lid but I am assuming it is connected to the socket in that assembly thing. I thought it might be related to the check engine since that code is for high voltage on the evaporative system, usually the fuel pressure sensor. But the fuel pressure sensor is under the car.
I will recheck the connections and make sure they are OK. If the speakers I removed are wired anything like this was, it was probably done horribly.
Old Apr 3, 2016
Fablejake's Avatar
Fablejake is an unknown quantity at this point
It's a seat ejector switch. This isn't uncommon. Great safety feature if done correctly.
Old Apr 3, 2016
Quit guessing. Open the dang cover and see what that wiring mess is really connected to.
P0171 is a lean code and those usually kinda suck to get figured out. If the pump is running at a lower voltage than intended because of a voltage drop caused by crappy wiring connections......I could see it happening.
P0453 FTP sensor high..... Doesn't seem like a high failure item.
Unplugged?
Rodent chewed wires are common to see in my area.
No, not really.
mattdoc
Mar 14, 2017 12:10 PM
ashleymmackey
Apr 18, 2015 09:48 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
bahena08
Apr 11, 2015 05:09 PM
