SRS Light
the SRS stays on for about 5 seconds then goes off if there is nothing wrong with the SRS system. it is doing a system check. if it stays on, then you have a problem.
that DIY only works if the system was working correctly but you disrupted something in the SRS system, like disconnecting a SRS component without disconnecting the battery. if there is a actual system fault, that reset wont help.
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
