Strut Spring Perch Problem: HELP
Old Mar 26, 2006
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
Exclamation Strut Spring Perch Problem: HELP
ok i tried searching out couldn't find the right thread....i believe this also happened with another member....
but i need help....the rear right of the car, bottom perch of the struts that holds the spring suddenly "gave in"
heres a pic (this from the DIY).... the red circle shows the right place the perch should be, the blue circle shows where MY perch is now, i check it out and raised the car, the perch and spring moves easily up and down....
dunno what to do???
Old Mar 27, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
dam, I've never heard of anything like that. I guess I'd replace that. If you still have a warranty, just get it replaced.
Old Mar 27, 2006
claudeboi's Avatar
heres an update...well, i had it snapped back in...it worked for awhile then it bottomed out again...that piece is not replaceable, the entire shock has to be replaced, this blows...so heres what i found out, the piece im talking about is not even welded on the shocks, its only clamped on tightly (very stupid of honda)...and you cant weld the piece back on cuz it will cause the fluid inside the shocks to heat and could cause an explosion....so now im trying to get a used shock...
just got my self a set of rsx struts and spring assembly thanks to em2typeflex.....thanks a lot man, my car should be fine by tomorrow, thanks a lot man.....
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
