Help! Car Won't Start!!!
Old Apr 6, 2006
drummerboy990's Avatar
drummerboy990 is an unknown quantity at this point
So I was driving back to school and the car was running fine. I got to school and parked the car and shut it off. Then I went to unlock my doors and they wouldn't unlock. Then I noticed none of the interior lights were on either, so I tried to retstart my car and it wouldn't even crank. I tried jumping it, but the car won't jump either. Some help would be much appreciated, this is pissing me off.
Old Apr 6, 2006
teg91ls's Avatar
teg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trustedteg91ls should not be trusted
Sounds like the battery. Try charging it
Maybe your battery is low on water
Old Apr 6, 2006
CraigW's Avatar
If the battery is drained that bad it will take a good charging before attempting to start. Sometimes a jump is not enough.
Old Apr 7, 2006
It actually turned out to be the 80A main fuse was damaged. It wasn't blown, just melted some. Does anyobody have any idea why this would happen?
Old Apr 7, 2006
CraigW's Avatar
Just keep a close eye on the replacement fuse to see if it does anything similar again.
What designation # was the fuse ?? (not amperage rating)
Anything electrical added to car ??
Braun
Apr 23, 2015 09:03 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
