crank no start
crank no start
Hi I really need help fixing my car here's what's happing I have had it parked for a while now to customized my interior I use to crank it up and just let it run so all the fluids would circulate properly so one day I pulled it up on a trailer to relocate it and it was running fine then it just cut off now it won't run again unless I put gas in the throttle body and turn the key I have changed the main relay and the other two behind the glove box I have check all the fuses inside and out I have cleaned up all the ground point that I could locate I have checked the injectors they are 12.5ohms I have installed a new fuel pump and filter I have checked the connector going into the the pump itv have power I can't here my pump coming on but after trying to crank it a few times I disconnect the fuel line from the filter and fuel starts pouring out I'm not getting fuel up to the injectors can someone please help thanks
Re: crank no start
Have you checked under the car to see if something hit on the trailer or ramp, maybe mashed the fuel line shut?
Re: crank no start
No it drove up on the trailer it was running while we tied it down then it cut off we thought it may have just ran out of gas but it had a full tank when when took it off the trailer
Re: crank no start
Does the green key symbol in the gauge cluster flash angrily while you are cranking it?
Wild Cranker
427
Jan 28, 2016 06:49 PM
Supramk3
May 8, 2015 11:16 AM
black2k1vtec
Dec 6, 2001 09:49 PM
