Horn and 4-way flashers are ONLY things that work!!
Old Feb 26, 2006
jack_h's Avatar
jack_h is an unknown quantity at this point
I started my car yesterday (2002 Civic Canadian LX version), and got out right away. I noticed it was no longer running (it did start though). Since then everything seems dead, with the exception of the horn and 4-way flashers. NOTHING else works, including headlights, radio, door locks, power windows, dome light, map lights, instrument lights, etc... When I put in the key and turn, there are no clicks, no sounds, no lights, nothing.
NOTE: It is not the battery, because the 4-way flashers and horn work fine (loud and bright). If these work fine, then the dome and map lights would certainly work.
Any ideas what the problem could be?
Thanks!
Old Feb 27, 2006
CraigW's Avatar
Check the large fuses in the under hood box.
Laurenhunter7
May 10, 2015 01:09 PM
ORskier
May 3, 2015 12:54 PM
Linda0818
Apr 23, 2015 11:30 AM
Fastfebur
Apr 22, 2015 01:37 PM
netcbc
Bolt-on Engine Performance
Nov 7, 2001 01:29 PM
