Hazards work, Signals don't
Old Apr 21, 2015
Fastfebur's Avatar
Fastfebur is an unknown quantity at this point
Exclamation Hazards work, Signals don't
Hey guys, 2003 Civic HX here.
Driving home the other night and noticed that my drivers turn signals weren't working. Proceeded to pull over and check it out. After looking at what I can in the dark I noticed some rubbed wires from the tire to the signal wires. (no idea how that happened). Drove home.
Next day, replaced the fuses that were blown from the exposed wires. Cut back the wires, soldered them and heat shrinked the new connections. Everything looks good now.
All wires connected, new bulbs and all good fuses in but no action from the turn signals. Hazards still work, but no blinks from either side.
Flasher/Hazard relay that's under the dash? Anyway to prove this before heading out to the Dealer?
Old Apr 21, 2015
Re: Hazards work, Signals don't
Test light, volt-ohm meter, and a wiring diagram?
Check
Fuse #5 in the engine compartment box
Fuse #19 in the dash box
Old Apr 22, 2015
Fastfebur's Avatar
Check
Fuses are all good. Have power going to the socket and flashing power going to the socket when hazards are engaged.
Old Apr 22, 2015
Now you need
Old Apr 22, 2015
CraigW's Avatar
"Have power going to the socket" What does that mean ??
Should only have voltage when flashers, or turn signal is on.
Grounding circuit OK ???
Old Apr 22, 2015
I think he's 'testing' while the hazards are on, and they work.
The problem is the turn signals don't work.
Old Apr 22, 2015
CraigW's Avatar
You may have to take a $$ gamble on the flasher relay.
https://www.civicforums.com/forums/a...4&d=1229192541
Maaachoooo
Turbo
Aug 27, 2015 01:49 AM
ORskier
May 3, 2015 12:54 PM
shaejb15
Apr 26, 2015 07:44 PM
alexkharden
Apr 23, 2015 07:13 PM
