srs light on nd tried the diy for it...HELP!
Old Mar 28, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
well after installing rsx seats the light came on for some reason even tho all the connections were plugged in and everything so i decided to do the diy to reset the srs. at the end where it would blink on and then off it would do that but then the light would just come bak on...am i doin this right?
well me and my friend did it and it worked nd everything saying it reset but when i turn the car bak on it doesnt go away....it still shows the light...
uh still need help....anyone plz lend me some help plz!
Last edited by crazyasian; Mar 28, 2006 at 03:18 PM. Reason: Automerged Doublepost
Old Mar 28, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
did your car come with the side air bags on the seats? If they did it has to do with harness on the passanger side. If not then your seatbelt harness wasn't hooked up correctly.
Old Mar 28, 2006
Slow Gold's Avatar
I hope I offend you... Get mad
Slow Gold will become famous soon enoughSlow Gold will become famous soon enough
here the best way i found to get rid of the srs light. go get some black tape... pull the cluster apart cut a small piece of tape and cover where the light is inside of the cluster... boom light is out...
Old Mar 28, 2006
crazyasian's Avatar
hahah but then when emissions and all that crapy legal stuff is checked on the car it will detect the srs. oh nd yes it comes with side airbags. so its nothing to do with the driver side? cause it worked when i put in the driver side 2 days ago and then when i pulled it out and then later put it bak in hooking things bak up...thats when i got the srs light. aite well its wierd too cause when my dad was in the passenger seat the "side airbag is off" light pops up whenever he leaned wierd. ill check it out again or put in my stock seats and see if it works.
Old Mar 29, 2006
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
loooool looks like you hooked up a paseenger sealbelt light switch to the srs light?
Old Mar 30, 2006
crazyasian's Avatar
fixed the problem. it was b.c i had the civic seat in the driver side and the rsx seat in the passenger side nd the computer was being confused so i tossed in the civic seat in the passenger nd now the light is gone. thx for the help guys
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
