rpms stuck at 2k.
Old Mar 6, 2006
spoonEM's Avatar
omgwtfbbq mod.
rpms stuck at 2k.
So I was driving home tonight and suddenly my engine wont drop below 2k at idle. I dont know what the hell the problem is. It is raining and the streets are wet. I have a CAI with no bypass valve, so that might be the problem. Not exactly sure tho.....need some help.
Old Mar 6, 2006
throttle cable got stuck on something, tps is screwed up, aic valve is clogged, etc. The engine light has to be on so just scan it and see what the problem is....
Old Mar 7, 2006
spoonEM's Avatar
omgwtfbbq mod.
well..heres the deal. My car is still pretty much brand new.CEL has been on due to race header. I think I may have just sucked up some water
Old Mar 7, 2006
well there ya go, new engine time. i would still have the codes read. there can be more than one stored.
Old Mar 7, 2006
streetglower's Avatar
if you sucked up water in the engine, your car wouldnt be running.
go scan the ECU. you may have logged a new cell due to a different problem.
Old Mar 8, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
yeah if your car sucked up water it wont be working. thats the problems with the damn CAI. shortram #1
Old Mar 10, 2006
jerseydetailer's Avatar
jerseydetailer has a little shameless behaviour in the past
how long has the cai been on the car?
Old Mar 10, 2006
Toaster's Avatar
Toaster is on a distinguished road
Had a problem similar to this after washing a car with no mods. Check your battery cables. I pulled both mine and cleaned them and put them back on. Had not had the problem since. Do not know if it was dirt posts or if it just needed to be reset although I tried just pulling the fuse for the ECU and it did not help. Atleast it wont cost you anything even if it does not work.
GritzNGravy
Aug 19, 2015 03:03 AM
Bonnabell
Aug 14, 2015 04:15 PM
jessica19699
Jul 29, 2015 05:51 AM
brennov8
Jul 13, 2015 12:57 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
