Strut Spring Perch Problem: HELP
Old Mar 26, 2006
claudeboi's Avatar
im a psychopath...what are you looking at?
claudeboi is an unknown quantity at this point
Exclamation Strut Spring Perch Problem: HELP
ok i tried searching out couldn't find the right thread....i believe this also happened with another member....
but i need help....the bottom perch that holds the spring suddenly "gave in"
heres a pic (this from the DIY).... the red circle shows the right place the perch should be, the blue circle shows where MY perch is now, i check it out and raised the car, the perch and spring moves easily up and down....
dunno what to do, I either have the perch welded back where it suppose to be or replace the shock....
Tedverseti
Apr 23, 2020 01:45 PM
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
