Battery light
Old Mar 28, 2006
Ricanwizard's Avatar
Ricanwizard is an unknown quantity at this point
Battery light
My battery light has been on since i've changed my altenator and the battery is good so how can i get the battery light off any suggestions?
Come on guys help a brotha out lol
Last edited by Ricanwizard; Mar 28, 2006 at 10:58 PM. Reason: Automerged Doublepost
Old Mar 28, 2006
um it should go off by itself, otherwise the alt is still broken. otherwise pull out the FI ECU fuse under hood. see the manual for details.
Old Mar 29, 2006
if i pull the fi ecu fuse then it should go off and if my battery is bad or alt. it would go back on right like normal?
Old Mar 29, 2006
yeah
Old Mar 29, 2006
CivicManDan's Avatar
CivicManDan is an unknown quantity at this point
not civic related but, i put 3 in a 93 escort in a week. sometimes the rebuilts are no good.... same with the parts yard. other than that i second gearbox.
Old Mar 29, 2006
ok thanx i am goin to try that out this weekend
Old Mar 31, 2006
Slammed99Si's Avatar
Slammed99Si is an unknown quantity at this point
battery
When changing the alternator it is easy to blow the fuse under the hood the alternator runs too. If you rewired the new alternator which I am assuming you did if it is high output you will not have connection issues because you ran new wires. so replace the fuse and it should turn the light off
Old Mar 31, 2006
Thanx i will try all the ideas everyone has giving me...
beantech
Jun 15, 2015 07:09 PM
HiImBrandon
Jun 1, 2015 07:34 AM
MiniMi
May 27, 2015 01:57 PM
trellex
May 24, 2015 04:39 PM
WLakers
May 4, 2015 06:23 PM
