Check engine light
Old Feb 16, 2006
jzuha01's Avatar
Championship White 04 Ex Coupe
jzuha01 is an unknown quantity at this point
Check engine light
Is there anyway to turn off the check engine light without taking the car to the dealer? I searched but I couldnt find anything thanks!
Old Feb 16, 2006
Slammed99Si's Avatar
Slammed99Si is an unknown quantity at this point
ya
autozone will shut it off by resetting your ECU - but if you have a bad sensor or somethign it will turn back on
Old Feb 16, 2006
jzuha01's Avatar
Do they charge for that?
Old Feb 16, 2006
dj02's Avatar
if you searched then you would of found the answer.
un plugg your battery for about 15min, 2nd fix pull the ecu fuse, dont know where it is? read your manual it will show you where its at. and last fix is search better there are many fix's out there.
Old Feb 16, 2006
streetglower's Avatar
^^^ exactly. there is a sticky thread at the top of this forum explaining exactly on how to reset it. it also explains what to do when the light comes on, please read that thread.
http://www.7thgencivic.com/forums/sh...d.php?t=223977
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
