cant drive in the rain
Old Feb 6, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
i cant drive in the rain anymore. everytime i hit a puddle, the right side of my car seems to start moaning REAL REAL loudly and everytime i apply the throttle, its EVEN louder. i also feel it in my shifter too. i have to pull to the side of the road and stop the car. and when i turn it on, i get a HORRIBLE sound like the ABS is clicking non-stop and then it will be all fine. is my ABS
Old Feb 6, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
errr....i thought i read something about water hitting the hot exaust pipes and something warping and causing a noise.....
Old Feb 7, 2006
burke420's Avatar
The World Is Yours!
my exhaust rattles when i hit a puddle of watter on the sway bar. i think the cold water hit the hot exhaust while it sits on the sway bar reacts it to bounce on the sway bar and mid-pipe.
Old Feb 7, 2006
02BLKCIVIC's Avatar
Official Rattlesnake Hunter
I have the same problem and I replaced my suspention twice and my exhaust once! And still have this problem!
Old Feb 7, 2006
my exhaust gets insanely loud in the rain like i don't have a muffler on. and its not rattle either. do you have aftermarket exhaust?
Old Feb 7, 2006
Karumba's Avatar
Boredom causes changes ;)
There was a bullentin for this from Honda .. but if you were like me with an oversided aftermarket (2.5" pipe), perhaps you can have a muffler shop look into bending the pipe slightly lower.
Old Feb 7, 2006
ya i saw that but mine doesn't rattle it just gets really loud (the tone it makes when moving).
Old Feb 8, 2006
02BLKCIVIC's Avatar
I do have aftermarket exhaust! The noise comes from the front right wheel! I can even hear it some times when I come to a STOP! It's like V V V V V V V V V V V VV WWWVVV! It sound SOOOO horiable! Dont know why or what caused it!
Old Feb 8, 2006
Zzyzx's Avatar
Autocross Junky
when you pull over, does it continue to make the sound with the engine off?
Old Feb 8, 2006
02BLKCIVIC's Avatar
NO! defintitally NOT! I can hear it make one or two more "BANGS" befor the engine STOPS! Then when I start it up... there it is again! I can feel a vibration all the way to the back my floor! Even when im the back seat! Drives me crazy!
Old Feb 8, 2006
ya the exhaust expands and starts knocking on the car.
Old Feb 8, 2006
Karumba's Avatar
Your midpipe is hitting on your shield - it was my problem.
Old Feb 8, 2006
02BLKCIVIC's Avatar
already removed the shield... but it could be hitting the floor, that makes sence! My exhaust isn't in the best condition!
Old Feb 8, 2006
you could try thermotec wrap but it will rub off eventually
Old Feb 8, 2006
02BLKCIVIC's Avatar
Ya I thought the same thing! But I dont want to SPENT another 60 bucks just to find out it ended up being my suspention! But... I probly will wrap it this weekend! I gota have this noise STOP!
Old Feb 9, 2006
gmcuajo's Avatar
gmcuajo can only hope to improve
An aftermarket exhaust will do that sound when hit water. The water makes the pipe cames cold rapidly this harden the metal then the sound. The "hard" pipe can't flex due to the car and engine vibrations. (Technically, in metal manufacturer this is how they do "heat-treatment" to a metal, of course with high temperatures.) Use a flexible union between the down-pipe and cat, or better after the cat.
About the wheel, I never heard something like that. But as the pipe becomes hard, the brake rotor did it too and bends when it hit water.
Old Feb 10, 2006
02BLKCIVIC's Avatar
One last question... I still hear the noise NOT in the rain! It does feel like it is my exhaust! But there is no rain. I can hear it under idle at a stop light??? could my exhaust be broken again?? any oppinions would be greatly appriciated! THX
Old Feb 10, 2006
Massimo-Ep2's Avatar
Massimo-Ep2 is an unknown quantity at this point
My opinion would be to check it out... get underneath your car and look carfully! Also you should check out your ''downpipe"(between header and cat). And if you modified your exhaust you didn't forget your gasket right? Hope you can solve your problem...
Old Feb 13, 2006
02BLKCIVIC's Avatar
nope never forgot the gasket.
Old Feb 14, 2006
familycar's Avatar
this is what happened to my car after i installe dthe exhaust cat pipe and header. the problem is there is too much tension on the exhaust system. so instead of allowing movement or flex at the header flange its all stiff and causing the exhaust to hit the body of the car under the shifter and ebrake assembly. i got my car on a lift and tried to fix it but was kind ***** footing around. basically i didnt want to take it all out and reinstall it. but that would have been the best idea. you need to bolt everything together then start form the back forward with the hangers and lastly bolt the header to the head. sthis should relieve any tension that the hanger and misaligned piping is causing. if not take it to a shop and have them mod your midpipe to pull the exhaust away from the body and realign the system correctly
Old Feb 14, 2006
02BLKCIVIC's Avatar
Hmmmmmm this is good advice THX, family
Old Feb 14, 2006
familycar's Avatar
no problem man
Xuhme
21
Aug 7, 2023 03:40 PM
usajags84
15
Aug 19, 2015 03:12 AM
sccarally
Texas
May 25, 2015 10:14 PM
ashlava71
May 16, 2015 12:54 PM
smmahan
Apr 15, 2015 08:17 PM
