problem w/ my hazard lights
Old Mar 31, 2006
ill02civic's Avatar
ill02civic will become famous soon enoughill02civic will become famous soon enough
my hazard light doesn't work ... replaced the fuse and everything..still doesn't work .. ...would anyone give me any other suggestion to where i should check ? greatly apreciated ...yes turn signals work...
Old Mar 31, 2006
solar's Avatar
solar is an unknown quantity at this point
First check the obvious and that would be the bulbs themselves, if they're okay then check the flasher. Do the turnsignals work?
Old Mar 31, 2006
ill02civic's Avatar
yah its not the bulb .... turn signal works .... im thinkin its the flasher...but where is that located..?
Old Mar 31, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Did you remove your center console? I did a couple days to adjust some cables behind my stereo and the hazard button didn't, so I unplugged it and plugged it back in and it worked.
Old Mar 31, 2006
flasher works if signals work. maybe you forgot to plug the switch in
Old Mar 31, 2006
ill02civic's Avatar
great i will try that this weekend ..
what switch u talking about ? if ur talkin about the flasher switch , i never touched that switch....
Last edited by ill02civic; Mar 31, 2006 at 03:20 PM. Reason: Automerged Doublepost
Old Mar 31, 2006
yeah just make sure it's the plug is snaps in tight. Also do you know how to remove the hazard button?
Old Mar 31, 2006
ill02civic's Avatar
k, nah i don't
Old Mar 31, 2006
just pull the console off. Take a flat head screw driver and push down on the hazard button from the backside. Do the same to bottom end and push from behind where the plug would go.
Munzy
21
Oct 7, 2015 07:48 AM
brash99
Sep 29, 2015 08:42 AM
IronFist
Sep 25, 2015 07:13 PM
Skunkone
Sep 24, 2015 04:38 PM
Bricoleur
Sep 9, 2015 12:23 PM
