HID Help
Old Apr 11, 2006
02civlx's Avatar
02civlx is an unknown quantity at this point
HID Help
I have installed HID in my 02 civic lx and at first, the DRL light on the dash comes on when the lights are off and highbeam light comes on when I have the lights on.
I managed to remove the DRL light on the dash by removing 2 fuses under the steering wheel (#2 7.5A and #13 10A that says Day Light), but I can't seem to remove the high beam symbol light on the dash. It comes on even when i turn on low beam only.
there are 3 colour wire for the headlight harness
(1) red with blue stripe
(2) red with yellow stripe
(3) red with white stripe
i tired the connecting the following ways:
1) negative to wire 1 and positive to wire 2 => no light
2) negative to wire 1 and positive to wire 3 => light (with high beam symbol light on dash
it is a low beam only H4 HID kit. Please help me remove that high beam symbol.
Old Apr 11, 2006
thisaintgino's Avatar
thisaintgino is an unknown quantity at this point
yeah i have had the same problem but i got 6500k h4 hi and low..is there a way to fix that?
Old Apr 11, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
Easy fix, you both need a wire harness. If you continue running the ballasts on the stock harness you will fry it. When you make a harness you're using only the low beam prong on one stock harness for both ballasts. If you need more help PM me. I could also make a harness if anyone wants it.
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
Voiceofid
Feb 3, 2002 03:54 PM
