TURN SIGNAL! turn signal.
Old Feb 11, 2006
mashieplunger's Avatar
mashieplunger is an unknown quantity at this point
hi, can any 1 tell show me how to fix my turn signal? it seem like is going nuts. When i try to put on the turn signal it flash once then it stop flashing. sometime it flashes very fast then stop.
is drivin me nuts! i been drivin like this for 1 month. need to find a way to fix it. can anny1 help?
i will post up a video of this deffect later.
Old Feb 11, 2006
maybe the bulb is burnt out.
Old Feb 11, 2006
streetglower's Avatar
does this happen with both sides or just one side?
Old Feb 16, 2006
it happen for both side. sometime it works and sometime it doesn't. Do you think is something to do with the fuses? because it blink and stop. sometime it blink for few times then stop.
Old Feb 16, 2006
bad wiring or flasher?
Old Feb 17, 2006
CraigW's Avatar
How about the emergency / 4 way flashers ? My first thoughts are flasher unit.
Old Feb 17, 2006
thw_goalie's Avatar
thw_goalie is an unknown quantity at this point
That happend to me once. My bulb was put it backwards. I didn't even know there was a wrong way to put them in... but since there are two little bumps, there's one way that is a lot easier than the other.
Not sure if that's your problem, but it might be.
Old Feb 18, 2006
spoonJDMlX's Avatar
spoonJDMlX is an unknown quantity at this point
lol how can a bulb be put in backwards?
Old Feb 18, 2006
ok i will check my flasher. thanks alot.
The emergency flasher works. but then it stops blinkin after a while.
Old Feb 18, 2006
yea if you knew how a flasher works, its very possible for it to mess up and blink erratically.
Old Aug 7, 2006
Moose03's Avatar
Moose03 is an unknown quantity at this point
i have the same problem how did u end up fixing it
Old Aug 7, 2006
its either the flasher or a burnt out bulb. check the bulb first.
Old Aug 8, 2006
Moose03's Avatar
i went to honda to ask for the flasher
she looked at me like i was crazy and suggested the relay is that wat u mean when u say the flasher or is it an actual part
Old Aug 8, 2006
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
If i was workin the parts counter and someone came in and told me they needed the flasher, or a flasher, i'd look at them like they were nuts too.
Old Aug 8, 2006
CraigW's Avatar
Honda calls it Turn signal / Hazard relay
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
my2k1vic
Jan 8, 2002 08:31 PM
