changing engines
Old Feb 27, 2006
ripspecv's Avatar
ripspecv is an unknown quantity at this point
changing engines
hey I was wondering if anyone here knew a website that would show me how to step by step to change a d17a1? If i have to ill buy the book i just dont want to.
Old Feb 27, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Buying the book would be the best way. Step by step directions are the way to go. Get the book, you'll thank yourself later.
Old Feb 27, 2006
ripspecv's Avatar
does anyone know about how long a normal swap takes. im just going one engine to another of the same kind.
Old Feb 27, 2006
XSRCivic's Avatar
what kinda tools you working with? if you have a good set of air tools,ratchets etc plus a engine hoist, you should be able to get the motor out and new one in within 2 days. Have you taken apart your car some? (head swaps etc) theres not much to it once you start pulling stuff off.
Old Feb 27, 2006
streetglower's Avatar
honestly, It shouldnt even take a day to remove an old engine and put in a new one. All you really need to do is disconnect the main wiring harness from the ECU then from the bulkhead and whatever hoses, exhaust piping, fuel lines, and disconnect the tranny from the engine and what not and remove the mounts and drop the engine. you really dont even need a manaul. But I know someone on here will post the instructions from the manaul. Or here is a DIY from the DIY section
http://www.7thgencivic.com/forums/sh...d.php?t=209405
Now if the engine you are going to install already has the wiring harness and everything else, it shouldnt take very long. With a couple of friends, it can be done in several hours.
thana
Jun 15, 2020 07:05 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
sysblack
May 13, 2015 08:55 PM
BootyDo
May 7, 2015 04:46 PM
Grey
16
Jan 27, 2002 11:34 PM
